Home > Td5 > Erratic idling TD5
Defender NZ
New Zealand 2003 Defender 90 Td5 HT Caledonian Blue
Erratic idling TD5
Gdday,
2003 TD5
15P engine.
92453 kms
Two weeks ago did the injectors and washers no problem.
Did all the bits and bobs, primed it, started straight away! ...................Only
For some unknown reason, when it goes back to idle, for about 20 or 30 second it runs a bit rough, and then settles
down again.....
It drives fine, as normal.
Checked the pump, fuel filter and non return filter in housing, changed FPR, checked throttle pot, ambient sensor, crank
sensor........
Put Hawkeye on, nothing shows up...
For my own sanity I had the injectors checked at a local Deplhi agent, all injectors passed as OK.
For once..... I'm absolutely stumped Crying or Very sad
Any one else had this perhaps ??
Cheers Thumbs Up
Post #765763 28th Mar 2019 10:43am
OsloBlue
Check turbo I'm on IG: https://www.instagram.com/osloblue42/
Post #765770 28th Mar 2019 11:13am
Defender NZ
Good thought Thumbs Up
Post #765771 28th Mar 2019 11:21am
Defender NZ
I'll check the turbo today, but it seems really strange, as before I did the washers and seals it was running fine, other than
the oil level creeping up ....
The strange thing is, it doesn't do it all the time, just from say 7 out of 10 times ? Confused
I will check the wiring of the loom going to the ECU, in case perhaps it has "chafed" somewhere?
Post #765828 28th Mar 2019 6:46pm
landy andy
Are you sure it didn’t do it before?
Post #765841 28th Mar 2019 8:07pm
Defender NZ
Yup
It was running alright before then.......
Now it seems to be running rougher on idle, particularly when cold.
Strangly, when it settles down again, it runs fine Confused
When doing the "bump" clearance I was distracted and I got the lobe the round way wrong on nr. 4, and the adjuster screw
broke Rolling Eyes !
I put everything on hold until I got a new adjuster screw.
Replaced the screw, but nothing seemed untoward, when doing the "bump" clearance then.
Ever since then it has been occuring.
Checked if I cracked the head, i.e.no diesel coming out when I activate the pump, and no creeping up of the oil level.
Possible I have cracked the head perhaps ??
It's a 15P engine, so by all accounts it's a stronger head Surprised
Post #765881 29th Mar 2019 12:13am
Procta
I would double check what you have done, just in case something has come slack. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #765889 29th Mar 2019 7:12am
landy andy
The reason I asked was that I think it’s not unusual for the Td5 to do this.
You drive along then stop driving, engine sounds like it’s running on four cylinders for a brief time, then returns to smooth/five cylinder tickover.
Post #765892 29th Mar 2019 7:53am
Defender NZ
Thanks boyz,
I checked more than once Smile for my own sanity, if nothing else. Laughing
Yes, exactly as you said Landy Andy that's what it does now, but it never used to Rolling Eyes
It sounds more like a bag of nails Laughing
I wonder if it is the fuel pump, not delivering enough fuel at idle, but I'm sure the FPR would regulate that Wink
Any thought.....
After all, I'm increasing feeling more and more of an idiot Big Cry
Post #765899 29th Mar 2019 8:29am
landy andy
From what I remember, with a discussion with a tuner, it’s just due to the Td5 shutting down injectors to lower the tickover. It’s more noticeable when you engine brake. My old Td5 90 used to do it a lot and that got to 186thou miles, and went like stink.
I was just thinking you maybe listening more, and worrying due to your recent work, but it had always done it a bit?
Post #765904 29th Mar 2019 8:57am
Defender NZ
Thanks Landy,
I know what you mean, when you notice something it plays on your mind Rolling Eyes .
Even the guys that work for me now notice it, and give me some stick for it Embarassed , as they are Nissan
and (blooming) Toyota fans. ( I HATE Toyota !! Big Cry )
I'll see if I can can make a sound recording and post that perhaps, so you can hear......
It seems to be worse when the engine is cold ?!?
Post #765996 29th Mar 2019 8:31pm
BigJohn
United Kingdom 2003 Defender 110 Td5 DCPU Java Black
Did you get to the bottom of this? Did you check for oil on the ECU plug?
Post #772838 12th May 2019 8:33pm
Defender NZ
I just got to the bottom of it Smile
It is a cracked head, strangly on nr. 2, not on nr.4 as I expected, due my own "senior" moment Very Happy
However I think may have been already cracked, as the "growing" oil has been going on for some time.
I have ordered a new AMC head, and it should be here by the end of next week I hope.
A bit dissapointing, as I haven't even reached the 100 K milestone yet.
We don't get the conditions here as in Europe, so my Defender has been pretty cosseted, and very much looked after Smile
Mind you first major spend since new, so as the saying goes : Censored happens Embarassed Shocked
Post #772847 12th May 2019 8:54pm
