![]() | Home > Td5 > Erratic idling TD5 |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Check turbo I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Defender NZ Member Since: 01 Sep 2018 Location: In de middle Posts: 13 ![]() ![]() ![]() |
Good thought
I'll check the turbo today, but it seems really strange, as before I did the washers and seals it was running fine, other than
the oil level creeping up .... The strange thing is, it doesn't do it all the time, just from say 7 out of 10 times ? ![]() I will check the wiring of the loom going to the ECU, in case perhaps it has "chafed" somewhere? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Are you sure it didn’t do it before?
Yup
It was running alright before then....... Now it seems to be running rougher on idle, particularly when cold. Strangly, when it settles down again, it runs fine ![]() When doing the "bump" clearance I was distracted and I got the lobe the round way wrong on nr. 4, and the adjuster screw broke ![]() I put everything on hold until I got a new adjuster screw. Replaced the screw, but nothing seemed untoward, when doing the "bump" clearance then. Ever since then it has been occuring. Checked if I cracked the head, i.e.no diesel coming out when I activate the pump, and no creeping up of the oil level. Possible I have cracked the head perhaps ?? It's a 15P engine, so by all accounts it's a stronger head ![]() |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5348 ![]() ![]() |
I would double check what you have done, just in case something has come slack. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
The reason I asked was that I think it’s not unusual for the Td5 to do this.
You drive along then stop driving, engine sounds like it’s running on four cylinders for a brief time, then returns to smooth/five cylinder tickover. |
Thanks boyz,
I checked more than once ![]() ![]() Yes, exactly as you said Landy Andy that's what it does now, but it never used to ![]() It sounds more like a bag of nails ![]() I wonder if it is the fuel pump, not delivering enough fuel at idle, but I'm sure the FPR would regulate that ![]() Any thought..... After all, I'm increasing feeling more and more of an idiot ![]() |
From what I remember, with a discussion with a tuner, it’s just due to the Td5 shutting down injectors to lower the tickover. It’s more noticeable when you engine brake. My old Td5 90 used to do it a lot and that got to 186thou miles, and went like stink.
I was just thinking you maybe listening more, and worrying due to your recent work, but it had always done it a bit? |
Thanks Landy,
I know what you mean, when you notice something it plays on your mind ![]() Even the guys that work for me now notice it, and give me some stick for it ![]() and (blooming) Toyota fans. ( I HATE Toyota !! ![]() I'll see if I can can make a sound recording and post that perhaps, so you can hear...... It seems to be worse when the engine is cold ?!? |
BigJohn Member Since: 02 May 2019 Location: Surrey Posts: 5 ![]() ![]() ![]() |
Did you get to the bottom of this? Did you check for oil on the ECU plug?
I just got to the bottom of it
![]() It is a cracked head, strangly on nr. 2, not on nr.4 as I expected, due my own "senior" moment ![]() However I think may have been already cracked, as the "growing" oil has been going on for some time. I have ordered a new AMC head, and it should be here by the end of next week I hope. A bit dissapointing, as I haven't even reached the 100 K milestone yet. We don't get the conditions here as in Europe, so my Defender has been pretty cosseted, and very much looked after ![]() Mind you first major spend since new, so as the saying goes : ![]() ![]() ![]() |
