![]() | Home > In Car Electronics > Blackvue dash cam owners - "power magic pro" quest |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917
So many daft questions; so little time...
I am looking to fit a blackvue dashcam, while my dash and headlining are out, giving me easy access to wire it neatly. I'm wondering about the "power magic pro" kit, which does away with the cigarette lighter plug. Here: https://www.blackvue.com/power-magic-pro#1...5489d-7d5c My question is simply - what's the round/cylindrical black thing that comes with the harness?? ( you can see it in the picture at the top of the page) I can't figure out why power wouldn't just be supplied up to the camera with a simple cable..? Does the camera plug into that thing? I've looked at th downloadable manual too, and it just says 'to the camera'... Just trying to decide it it's worth the money, or do I just cut off the cigarette plug and splice the camera into my aux fuse box. Using the kit allows me to use parking mode, which I think might be handy in some places. Ta Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Its a hard wired kit that is meant to switch it off before it flattens the battery - not sure it works depending on where you park as cats / trees moving / other traffic must set it off as I have reams of recordings of nothing reall, and only just enough juice to start the engine.
I've taken to pulling the plug out and powering off when its parked safely. HTH Keith |
Thanks ickle,
I bought a pair of the DR590 ones. I think they rely on motion or a bump to start the parking recording, rather than being motion sensing. I think I know what the wiring kit is for, I just can't understand what the black cylinder is...? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Ah! It's a socket to put the cigarette plug cable into! Thanks very much for that. I guess it's obvious enough - but their pictures don't show it as such.
Like you say, it wasn't on my radar for a 'hard wired' solution, so I wasn't expecting that at all. I think I'll be doing something neater than that right enough. Is the polarity thing obvious enough? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
I’ve just hard wired mine to be on all the time as I’m running it every day and I just unplug it if I’m away
