Home > Maintenance & Modifications > Missing door seal
j17
Missing door seal
We’ve been enjoying the new defender over last couple of weeks however the wife has been mentioning a draft coming from around the seatbelt b post, she mentioned it a few times so I had a look this afternoon.
There seems to a seal missing
Does anyone know the part I need and do I have to take the ‘sill’ off to fit it?
Jit
Post #761426 1st Mar 2019 8:48pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Where abouts is the missing seal? On mine the seal goes all around the door frame from bottom left corner, all around the top of the frame, to bottom right and its a single long piece. There's then also a seal along the bottom of the door.
Post #761430 1st Mar 2019 9:10pm
j17
I uploaded some pics, they’re showing in ‘my gallery’
This is from 2013 usw
All the other doors do not have the gap as shown in the pics
Post #761433 1st Mar 2019 9:19pm
donmacn
Ah! I'm going to have to do some serious draught-proofing soon.... I have one like this on the driver's side in my car.
There's a few things I've wondered about as possible causes:
The 'bung' in the bottom of the B pillar. I think there should be one, and I think mine's missing. My reasoning is that without it, air might be drawn up the B pillar while the car's moving, and then escape from the slot for fixing the 2nd row door hinges. I'll see if that makes a difference easily enough, just by putting some tape over those hinge bolt holes
Another option I've wondered about is maybe up through the battery box. Depending on what carpet or mat arrangement you might have. Or maybe up via the plate that fixes under the cubby box.
And, another thought I had was a draught coming through the door cards. My car's missing the small 'corner pieces' that go with the window seals. There are huge gaps there.
And then there's the mystery blast of cold air that seems to hit the gearstick on right hand bend.... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #761437 1st Mar 2019 9:28pm
donmacn
Just seen your pics - pretty sure there isn't meant to be a seal there. I don't have one anyway. Donald
in the past..
Post #761441 1st Mar 2019 9:30pm
j17
All other doors do not have this gap
I was expecting some draughtiness but several times I’ve looked over at the passenger door and it sounds like it’s not closed properly- this is the reason!
Post #761442 1st Mar 2019 9:34pm
dorsetsmith
the bottom door seal closes against outer edge floor orange arrow
maybe the door needs to adjusted
Post #761445 1st Mar 2019 9:43pm
j17
I don’t have a door seal like that, it’s dark now so not great pics
This is a pic of the rear door opening, there is a rubber seal in the gap
Post #761449 1st Mar 2019 10:05pm
donmacn
Do these improved door seals fit on earlier doors? The TDI ones, or the newer 'round corners' galvanised ones? Donald
in the past..
Post #761453 1st Mar 2019 10:12pm
dorsetsmith
you need to add seal and then adjusted door if necessary
LR029309 bottom door seal front 2007 to 2016
second row bottom doors seal are LR029307 and LR029308 -110 130
Post #761454 1st Mar 2019 10:12pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
its a stick on foam seal - Mine fell off/fell apart. The whole sill needs to be unbolted, cleaned and old bits of seal removed with white spirit. The new seal sticks onto the sill. 1953 80"
1987 mini city e
2011 90"
Post #761456 1st Mar 2019 10:14pm
j17
Ok thanks, so I just need to get some foam seal stuff, I’m guessing it’s fallen off at some point
Do you have the door seals pictured above?
Post #761458 1st Mar 2019 10:21pm
MR_JAMES
no my door seal is 2011 so slightly different, your missing the lower door seal as well as the sill foam. 1953 80"
1987 mini city e
2011 90"
Post #761461 1st Mar 2019 10:37pm
dorsetsmith
ALR6368 - SEAL SILL TO FLOOR DEFENDER
Post #761467 1st Mar 2019 11:21pm
The foam seal between the cill and the floor will not cure your draught problem. You need to fit the missing rubber seal to the bottom of the door.
Unfortunately not. The door frames are very different shapes. Darren
Post #761504 2nd Mar 2019 10:54am
