![]() | Home > Maintenance & Modifications > Missing door seal |
| cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123 |
You may find this useful? Post fit of newer door seals.
http://defender90xs.blogspot.com/2014/08/u...seals.html |
| j17 Member Since: 21 Jan 2019 Location: West Midlands Posts: 59
Thanks for all the help
I have checked this morning and only the passenger door is missing the door seal and the foam insert - not sure why??? but I will get the parts ordered this week |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917
Not picking a fight! Just wondered what we might collectively think of this: http://defender90xs.blogspot.com/2014/08/u...seals.html I've just put new, genuine lower seals on my new doors, and there is clearly a couple of inches on either end that isn't covered/sealed. I could use some foam blocks - I think that's what's supposed to be there - but I'm still tempted by using these bigger seals. This lad has done it with just a couple of extra holes on the sides of the doors. It does look from some of the photos that the seals might be a little proud on the sides of the doors, but other than that, seems to work OK? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Ok, I'll revise my answer to 'not without a degree of faffing around and even then not very well'
I am tempted though. Not just because of the bits that come up the sides, but also because the bit along the bottom of the door seems more substantial than what's basically a bit of rubber with a 90' bend in it! Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
