![]() | Home > Maintenance & Modifications > Missing door seal |
| JPE Member Since: 19 Nov 2018 Location: South West England Posts: 347
Where abouts is the missing seal? On mine the seal goes all around the door frame from bottom left corner, all around the top of the frame, to bottom right and its a single long piece. There's then also a seal along the bottom of the door.
| j17 Member Since: 21 Jan 2019 Location: West Midlands Posts: 59
I uploaded some pics, they’re showing in ‘my gallery’
This is from 2013 usw All the other doors do not have the gap as shown in the pics |
| donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1917
Ah! I'm going to have to do some serious draught-proofing soon.... I have one like this on the driver's side in my car.
There's a few things I've wondered about as possible causes: The 'bung' in the bottom of the B pillar. I think there should be one, and I think mine's missing. My reasoning is that without it, air might be drawn up the B pillar while the car's moving, and then escape from the slot for fixing the 2nd row door hinges. I'll see if that makes a difference easily enough, just by putting some tape over those hinge bolt holes Another option I've wondered about is maybe up through the battery box. Depending on what carpet or mat arrangement you might have. Or maybe up via the plate that fixes under the cubby box. And, another thought I had was a draught coming through the door cards. My car's missing the small 'corner pieces' that go with the window seals. There are huge gaps there. And then there's the mystery blast of cold air that seems to hit the gearstick on right hand bend.... Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... Last edited by donmacn on 1st Mar 2019 9:31pm. Edited 1 time in total |
Just seen your pics - pretty sure there isn't meant to be a seal there. I don't have one anyway. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Click image to enlarge Click image to enlarge All other doors do not have this gap I was expecting some draughtiness but several times I’ve looked over at the passenger door and it sounds like it’s not closed properly- this is the reason! |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge the bottom door seal closes against outer edge floor orange arrow maybe the door needs to adjusted Last edited by dorsetsmith on 3rd Mar 2019 6:18pm. Edited 1 time in total |
I don’t have a door seal like that, it’s dark now so not great pics
Click image to enlarge This is a pic of the rear door opening, there is a rubber seal in the gap Click image to enlarge |
Do these improved door seals fit on earlier doors? The TDI ones, or the newer 'round corners' galvanised ones? Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
you need to add seal and then adjusted door if necessary
LR029309 bottom door seal front 2007 to 2016 second row bottom doors seal are LR029307 and LR029308 -110 130 Last edited by dorsetsmith on 1st Mar 2019 10:25pm. Edited 3 times in total |
| MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 270
its a stick on foam seal - Mine fell off/fell apart. The whole sill needs to be unbolted, cleaned and old bits of seal removed with white spirit. The new seal sticks onto the sill. 1953 80"
1987 mini city e 2011 90" |
Ok thanks, so I just need to get some foam seal stuff, I’m guessing it’s fallen off at some point
Do you have the door seals pictured above? |
no my door seal is 2011 so slightly different, your missing the lower door seal as well as the sill foam. 1953 80"
ALR6368 - SEAL SILL TO FLOOR DEFENDER
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
The foam seal between the cill and the floor will not cure your draught problem. You need to fit the missing rubber seal to the bottom of the door.
Unfortunately not. The door frames are very different shapes. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
