Home > In Car Electronics > Factory sub question
mcma1
I want to add a sub, ideally the factory unit on the back off the cubby, is the connection part off the loom hidden underneath? Or did they make looms that didn’t have this for the defender that did not have it specc’d? I had the cubby out and it def not sticking out but I doubt they would leave it underneath? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #757741 10th Feb 2019 2:13pm
Martin
Site Admin
The loom is sometimes there on cars which weren't fitted with the sub.
No pattern either - mine's a 2015 XS 90 without, but people have reported base hardtops with the plug in place.
It's an obvious plug underneath the cubby box - have a search there are photos in previous threads on here Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #757803 10th Feb 2019 7:06pm
Co1
I have a HT without the factory amp, but the plug is there under the box. Whip it out and have a look. Incidentally, if you do fit it, let me know how much of a difference it makes as I was thinking of getting one.
Post #757807 10th Feb 2019 7:15pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Just fitted one. Even though I bought the appropriate harness still needed another power feed wired in.
The difference is incredible. Have had to turn the sub power right down because there is SO much bass. Shakes everything in the cubby. https://instagram.com/bentheoandrews
Post #757808 10th Feb 2019 7:18pm
CarMan
Also very pleased with mine but no plug under the cubby sadly in my MY16 XS HT even though there was in my previous povetry spec HT of the same age Confused
Had the local ICE folk today install it. Smile Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #757810 10th Feb 2019 7:25pm
Martin
Site Admin
Got a part number for the extra harness please?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #757812 10th Feb 2019 7:39pm
Farmerben
Post #757820 10th Feb 2019 8:10pm
Martin
Site Admin
Cheers Smile I can see from your other thread you had the sub connector in place already and just needed this phono adapter Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #757824 10th Feb 2019 8:22pm
Farmerben
I thought it would just be a case of plug and go but had to take it into an auto electrician to get it fired up. https://instagram.com/bentheoandrews
Post #757828 10th Feb 2019 8:38pm
mcma1
I had the sub in the last one and miss it. Def not there as I had the cubby out so will have to go down a different route it seems. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #757830 10th Feb 2019 8:45pm
