![]() | Home > In Car Electronics > Factory sub question |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
I want to add a sub, ideally the factory unit on the back off the cubby, is the connection part off the loom hidden underneath? Or did they make looms that didn’t have this for the defender that did not have it specc’d? I had the cubby out and it def not sticking out but I doubt they would leave it underneath? Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
The loom is sometimes there on cars which weren't fitted with the sub.
No pattern either - mine's a 2015 XS 90 without, but people have reported base hardtops with the plug in place. It's an obvious plug underneath the cubby box - have a search there are photos in previous threads on here ![]() ![]() ![]() |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 607 ![]() ![]() ![]() |
Just fitted one. Even though I bought the appropriate harness still needed another power feed wired in.
The difference is incredible. Have had to turn the sub power right down because there is SO much bass. Shakes everything in the cubby. https://instagram.com/bentheoandrews |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1893 ![]() ![]() |
Also very pleased with mine but no plug under the cubby sadly in my MY16 XS HT even though there was in my previous povetry spec HT of the same age
![]() Had the local ICE folk today install it. ![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Got a part number for the extra harness please? ![]() ![]() |
LR040847 https://instagram.com/bentheoandrews
I thought it would just be a case of plug and go but had to take it into an auto electrician to get it fired up. https://instagram.com/bentheoandrews
I had the sub in the last one and miss it. Def not there as I had the cubby out so will have to go down a different route it seems. Andy
