Home > Technical > Wiper and washers stopped working!
Tepidboy
Hi new to this website!
I see a lot of threads about wipers not working. Looks like a weak point ( of many!) On the defender.
Last week I turned the wipers on and found the blades were completely frozen to the windscreen. Defrosted the window released the blades but no action from the wipers nor the washers.
I have checked the fuses and they are all okay. I have replaced the wiper stalk still no joy.
Just wondering what next to check? If both the wipers and washers are down is there any point in replacing the relay?
If the washers are not working is there any point in checking the wiper motor switch?
Any advice would be appreciated
My defender is TDCI 2013
Post #756213 4th Feb 2019 2:53pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I’ve had plenty of wiper woes but never the issue of both wipe and wash not working simultaneously .
I should think it’s related to the actual wiper stalk on the steering column, there’s nothing else that springs to mind . Although I’ll no doubt be corrected in a bit !
The contacts are notoriously sensitive on both stalks and any overload could have melted one or two points.
Post #756223 4th Feb 2019 3:16pm
landy andy
If wipers were operated whilst frozen, so not able to move, I would expect the fuse to blow, I know you have checked this, but I would double check it. The next stage is to determine if you are getting 12v to motor. If yes motor has failed, if no it’s fuse, relay, or switch.
Post #756225 4th Feb 2019 3:18pm
Turn it on, then give the wipers a nudge and keep clear.
You might find this will do the trick.
Try carefully manually operating them and just becaregul if they do spring into life. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #756234 4th Feb 2019 3:27pm
Tepidboy
Cheers chaps,
It made sense to me that it would be a fuse or stalk issue. But I have double checked the fuses and all are fine. I have also replaced the stalk and still no joy.
Not sure where to go with this as if both washer and motor are not working there must be some common fault somewhere...?
Post #756235 4th Feb 2019 3:27pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Can you hear the wiper motor turning?
Post #756236 4th Feb 2019 3:29pm
Tepidboy
No noise and manually moving the wipers whilst on doesn’t work either 😤
Post #756241 4th Feb 2019 3:32pm
Bluericky
Well I suppose the leaves you with the relay . The washer wiper synchronisation must go through a relay in order for it to work as one
Post #756249 4th Feb 2019 3:45pm
Tepidboy
Ok I’ll try the relay and report back
Post #756252 4th Feb 2019 3:49pm
Martin
Site Admin
Which fuses have you looked at? Have you done a visual inspection only or tried swapping known good replacements to check?
Supply to wiper feed relay is Fuse 12 (15 Amps)
Also check Fuse 9 (engine ECU ignition sense).
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #756264 4th Feb 2019 4:45pm
Tepidboy
Right, relay changed and still no joy!
I’ve visually checked all fuses and swapped the relevant fuse.
My fuses are numbered differently to the ones you mention.
Post #756269 4th Feb 2019 5:00pm
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
Mine is Fuse 11.
Post #756271 4th Feb 2019 5:04pm
Martin
Site Admin
OK I was working with 2012 model year diagram, apologies.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #756277 4th Feb 2019 5:48pm
Marks Landy
Have you got access to a multi meter ?
Post #756295 4th Feb 2019 6:52pm
Tepidboy
Yes I do. What should I be testing?
Post #756313 4th Feb 2019 8:10pm
