![]() | Home > Technical > Wiper and washers stopped working! |
Are the wiper spindles seized? Ray
Tepidboy Member Since: 20 Dec 2018 Location: Cheshire Posts: 12 ![]() ![]() |
There is resistance when pulled but I think this is the motor.
What about the earth issue with the new stalk? |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
No, the stalk isn't earthed by the column. It should work independently. Darren
So stalk checked, fuses checked, relay checked.... I’m really at a loss now ?!?!?!?!
Have you checked if you've actually got power at the stalk, or anywhere else in the systems? As both washers and wipers have stopped, it's either a common connection point or a very strange coincidence. Darren
So I’ve been quiet as I’ve been busy!
Dash out and fault finding now on the wires. Manages to track it down to a fault on the green and red live feed( I think!). I reckon it has failed on the splice for the washer and wiper split. This is the only split in the full length of this wire. But does anyone know where this splice is so I can inspect it? |
Ptarmiganevents Member Since: 22 Jan 2018 Location: Luss Posts: 2 ![]() ![]() ![]() |
Did you find out what the fault was in the end? My wipers and washer packed in yesterday so faced with the same issue and symptoms you have experienced 😟
