![]() | Home > Technical > Wiper and washers stopped working! |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
I’ve had plenty of wiper woes but never the issue of both wipe and wash not working simultaneously .
I should think it’s related to the actual wiper stalk on the steering column, there’s nothing else that springs to mind . Although I’ll no doubt be corrected in a bit ! The contacts are notoriously sensitive on both stalks and any overload could have melted one or two points. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5976 ![]() ![]() |
If wipers were operated whilst frozen, so not able to move, I would expect the fuse to blow, I know you have checked this, but I would double check it. The next stage is to determine if you are getting 12v to motor. If yes motor has failed, if no it’s fuse, relay, or switch.
Turn it on, then give the wipers a nudge and keep clear.
You might find this will do the trick. Try carefully manually operating them and just becaregul if they do spring into life. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Tepidboy Member Since: 20 Dec 2018 Location: Cheshire Posts: 12 ![]() ![]() |
Cheers chaps,
It made sense to me that it would be a fuse or stalk issue. But I have double checked the fuses and all are fine. I have also replaced the stalk and still no joy. Not sure where to go with this as if both washer and motor are not working there must be some common fault somewhere...? |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306 ![]() ![]() ![]() |
Can you hear the wiper motor turning?
No noise and manually moving the wipers whilst on doesn’t work either 😤
Well I suppose the leaves you with the relay . The washer wiper synchronisation must go through a relay in order for it to work as one
Ok I’ll try the relay and report back
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
Which fuses have you looked at? Have you done a visual inspection only or tried swapping known good replacements to check?
Supply to wiper feed relay is Fuse 12 (15 Amps) Also check Fuse 9 (engine ECU ignition sense). ![]() Click image to enlarge ![]() ![]() |
Right, relay changed and still no joy!
I’ve visually checked all fuses and swapped the relevant fuse. My fuses are numbered differently to the ones you mention. ![]() Click image to enlarge |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Mine is Fuse 11.
OK I was working with 2012 model year diagram, apologies.
Have you got access to a multi meter ?
Yes I do. What should I be testing?
