Home > For Sale & Wanted > Wanted: Disco2 Transfer Box
Martin
Site Admin
Hi all,
I'm (again) after a D2 transfer box for my 90, doesn't matter if manual/auto/Td5/V8 but must have diff lock as I don't have fancy electronics to get me unstuck Wink
Thanks
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #70642 12th May 2011 12:28pm
I am sure you're aware that Disco2 transfer boxes with difflocks are fairly rare and tend to be snapped up by people like me who have Disco2s without any of the difflock internals. There is however no reason why you can't transplant the front wheel drive take-off including difflock from a 90 tbox onto a Disco2 tbox if you are after it just for the ratios.
I do have a Disco2 tbox with difflock which is going to donate its difflock to my Disco2, so if a box with no front-wheel drive housing etc is any use, let me know.
Post #70663 12th May 2011 1:45pm
Martin
Site Admin
Early boxes (99-01) and very late boxes (04) all had the diff lock internals and external drive peg, 2002/3 boxes didn't unless diff lock was specified as a factory option.
So I know that there are
I was hoping to be able to do a straight swap and not "break open" either box to swap parts, but do let me know how much you'd be after for your half-a-box! Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #70669 12th May 2011 2:01pm
There is one (with difflock) on the bay at the moment:
http://cgi.ebay.co.uk/DISCOVERY-SERIES-2-T...0312914879
Also this one, but I can't tell if it has the difflock or not:
http://cgi.ebay.co.uk/LAND-ROVER-DISCOVERY...0547455856
Post #70679 12th May 2011 3:08pm
Martin
Site Admin
Thanks for those, been keeping a beady eye on the 'bay for a while Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #70689 12th May 2011 3:34pm
McS
Just out of curiosity, why a D2 tbox? What advantages does it offer? And what ratio is it?
Ross The Scotia Winch Challenge
Post #70694 12th May 2011 3:48pm
Martin
Site Admin
Widely known to increase final drive ratio on a Defender Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #70701 12th May 2011 4:23pm
D2 box was modified for quieter operation hence LT230Q, earlier boxes were not hence LT230.
Having said that, I am not sure exactly what the differences were and I would have thought that for example a 300TDi tbox would fit a 90. I don't know if the gearbox to tbox interface changed at all. One difference between Disco1 and Disco2 was the removal of the gear levers from the top of the box to floor mounting, hence all controls were cable not rod operated.
The other major difference of course was the regrettable omission of the CDL on many D2 boxes!
Post #70702 12th May 2011 4:24pm
McS
obviously not that "widely" Martin....
so why not just fit a 1.2 tbox from a disco 1?
as said above, the control levers need some thought, probably best done with 2 seperate levers for low/hi and difflock....
Post #70704 12th May 2011 4:27pm
ibexman
I took my 2006 td5 to ashcoft for the day and had 230q gears fitted for around £600 saves all that phafing around doing it yourself
Post #70710 12th May 2011 5:02pm
Glynparry25
I am with Ibexman. When I was having issues with my D1 V8, I went through 2 'good' second hand ones (in 8 months) at £100 each and over £100 of oil (I did all the work so free) and then finally stumped up the £350 for a fully reconditioned one and it is still all happy 2 years later.
Buy cheap.... buy twice (or 3 times in my case), lol.
Good luck,
Glyn Dog Sheep
Post #70728 12th May 2011 7:33pm
Martin
Site Admin
I need the Td5 spec hi/lo sensor for my Td5 engine - not fitted to D1 boxes.
Linkages would be taken from my existing box.
I'm not here to start a row about which box to use, just seeing if anyone has a D2 transfer box Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #70743 12th May 2011 9:00pm
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
What effect does the Hi/Lo sensor have on the ecu and therefore the engine? I'm guessing that it cuts throttle response slightly (can;t say i've ever noticed though!!)?
Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #70794 13th May 2011 9:27am
BigMike
Poor martin, all he wants is a box. Next minute he'll be offered marital advice Laughing
Post #70795 13th May 2011 9:33am
Martin
Site Admin
Quote:
With low range selected on the new LT230Q transfer box, the ECU enables Fast Throttle Control (FTC) which widens pedal travel, giving more control over the engine speed in off road and low speed operation.
2015 D90 XS SW
Post #70796 13th May 2011 9:34am
