![]() | Home > For Sale & Wanted > Wanted: Disco2 Transfer Box |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6687 ![]() ![]() ![]() |
Hi all,
I'm (again) after a D2 transfer box for my 90, doesn't matter if manual/auto/Td5/V8 but must have diff lock as I don't have fancy electronics to get me unstuck ![]() Thanks Martin ![]() ![]() |
Early boxes (99-01) and very late boxes (04) all had the diff lock internals and external drive peg, 2002/3 boxes didn't unless diff lock was specified as a factory option.
So I know that there are I was hoping to be able to do a straight swap and not "break open" either box to swap parts, but do let me know how much you'd be after for your half-a-box! ![]() ![]() ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17878 ![]() ![]() ![]() |
There is one (with difflock) on the bay at the moment:
http://cgi.ebay.co.uk/DISCOVERY-SERIES-2-T...0312914879 Also this one, but I can't tell if it has the difflock or not: http://cgi.ebay.co.uk/LAND-ROVER-DISCOVERY...0547455856 |
Thanks for those, been keeping a beady eye on the 'bay for a while
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 ![]() ![]() |
Just out of curiosity, why a D2 tbox? What advantages does it offer? And what ratio is it?
Ross The Scotia Winch Challenge |
Widely known to increase final drive ratio on a Defender
D2 box was modified for quieter operation hence LT230Q, earlier boxes were not hence LT230.
Having said that, I am not sure exactly what the differences were and I would have thought that for example a 300TDi tbox would fit a 90. I don't know if the gearbox to tbox interface changed at all. One difference between Disco1 and Disco2 was the removal of the gear levers from the top of the box to floor mounting, hence all controls were cable not rod operated. The other major difference of course was the regrettable omission of the CDL on many D2 boxes! |
obviously not that "widely" Martin....
so why not just fit a 1.2 tbox from a disco 1? as said above, the control levers need some thought, probably best done with 2 seperate levers for low/hi and difflock.... Ross The Scotia Winch Challenge |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
I took my 2006 td5 to ashcoft for the day and had 230q gears fitted for around £600 saves all that phafing around doing it yourself
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I am with Ibexman. When I was having issues with my D1 V8, I went through 2 'good' second hand ones (in 8 months) at £100 each and over £100 of oil (I did all the work so free) and then finally stumped up the £350 for a fully reconditioned one and it is still all happy 2 years later. Buy cheap.... buy twice (or 3 times in my case), lol. Good luck, Glyn ![]() ![]() |
I need the Td5 spec hi/lo sensor for my Td5 engine - not fitted to D1 boxes. Linkages would be taken from my existing box. I'm not here to start a row about which box to use, just seeing if anyone has a D2 transfer box ![]() ![]() ![]() |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 230 ![]() ![]() ![]() |
What effect does the Hi/Lo sensor have on the ecu and therefore the engine? I'm guessing that it cuts throttle response slightly (can;t say i've ever noticed though!!)? Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Poor martin, all he wants is a box. Next minute he'll be offered marital advice
