Home > Td5 > Transmission/transferbox whine.
Page 2 of 2 <12
landy andy
Fitting disco gears to Defender transfer box is brilliant, especially if you have a remap. I loved it in my previous Td5, and am now considering what to do with my new Td5, as it has a standard transfer box, and I won’t let ashcrofts touch anything of mine. So I either need to fit my own gearing, or find an alternative. I don’t ever recall it being too highly geared even towing a digger, but when doing manoeuvres I would use low ratio.
Post #752031 18th Jan 2019 12:20am
Harry.O
Ashcroft have recently started doing custom transfer box ratios
https://www.ashcroft-transmissions.co.uk/lt230-ratio-changes.html
I have slightly larger tyres (285 75 r16) and a v8 5th gear ratio on my TD5 and am seriously considering a 1.3 box to give it longer legs on the motorway without inhibiting towing capacity too much 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #752037 18th Jan 2019 6:33am
D90JAP
So had a quick look underneath today and found that the transfer box fitted is a 1.667 ratio. Is that normal for a 2004 hardtop to have that from standard? I was under the impression that it should be a 1.4.
Post #753246 23rd Jan 2019 12:27am
dorsetsmith
1.4 as factory fitted to TD5 1987 to 2006
large tyre option 1.667 ratio.
Post #753282 23rd Jan 2019 9:26am
D90JAP
Mine is fitted with 235/85/16 guessing they are standard and it is a county pack.
Post #753286 23rd Jan 2019 9:39am
ashtrans
Site Sponsor
many TD5 LT230's were 1.410 type 43D's but had the 1.667 sticker put on in error,
Dave Dave
Post #753346 23rd Jan 2019 1:39pm
D90JAP
Is there any other way to tell from serial number what is fitted?
Post #753361 23rd Jan 2019 3:09pm
ashtrans
Site Sponsor
Yes, if it starts 43D (which is most likely) it’s a 1.410 Dave
Post #753734 24th Jan 2019 9:39pm
D90JAP
Thanks for everyone’s help and options with Thais much appreciated. I really wanted to go down the line of a roamerdrive but I couldn’t justify the price and also found that the transfer box that was fitted was whining internally. I opted for a discovery 1.2 and I have to say alongside the Alive tuning remap I’m running works and runs perfectly, no troubles with hill starts or anything. Seems to help with fuel consumption also. Once i brim the tank I will give some feed back on mpg for anyone else looking to change.
Thanks again folks.
Jack
Post #755146 31st Jan 2019 12:26am
Page 2 of 2 <12
