Home > Td5 > Transmission/transferbox whine. |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 704 |
Ashcroft have recently started doing custom transfer box ratios
https://www.ashcroft-transmissions.co.uk/lt230-ratio-changes.html I have slightly larger tyres (285 75 r16) and a v8 5th gear ratio on my TD5 and am seriously considering a 1.3 box to give it longer legs on the motorway without inhibiting towing capacity too much 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
18th Jan 2019 6:33am |
D90JAP Member Since: 13 Jan 2019 Location: Aberdeen Posts: 14 |
So had a quick look underneath today and found that the transfer box fitted is a 1.667 ratio. Is that normal for a 2004 hardtop to have that from standard? I was under the impression that it should be a 1.4.
23rd Jan 2019 12:27am |
1.4 as factory fitted to TD5 1987 to 2006
large tyre option 1.667 ratio. |
23rd Jan 2019 9:26am |
Mine is fitted with 235/85/16 guessing they are standard and it is a county pack.
23rd Jan 2019 9:39am |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 254 |
many TD5 LT230's were 1.410 type 43D's but had the 1.667 sticker put on in error,
Dave Dave |
23rd Jan 2019 1:39pm |
Is there any other way to tell from serial number what is fitted?
23rd Jan 2019 3:09pm |
Yes, if it starts 43D (which is most likely) it’s a 1.410 Dave
24th Jan 2019 9:39pm |
Thanks for everyone’s help and options with Thais much appreciated. I really wanted to go down the line of a roamerdrive but I couldn’t justify the price and also found that the transfer box that was fitted was whining internally. I opted for a discovery 1.2 and I have to say alongside the Alive tuning remap I’m running works and runs perfectly, no troubles with hill starts or anything. Seems to help with fuel consumption also. Once i brim the tank I will give some feed back on mpg for anyone else looking to change.
Thanks again folks. Jack |
31st Jan 2019 12:26am |
