Home > Td5 > Wolf Door - Check Straps |
https://www.lrworkshop.com/diagrams/land-r...es-3-doors
series 3 1971 to 1985 / Wolf front Door check strap mounts body end part number 346878 TD5 1998 to 2006 original door check strap mounts door end Bracket Assy - Door Check Arm LH - BDU710150 - Genuine Bracket Assy - Door Check Arm RH - LR020251 - Genuine Last edited by dorsetsmith on 31st Dec 2018 9:37am. Edited 4 times in total |
31st Dec 2018 8:45am |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 621 |
You could bodge it using the series 3 items above - as shown on the red door. Only joking, just attached that photo to illustrate your dilemma! Also if you have door cards they’ll won’t fit or need cutting to adapt.
However the Wolf check strap will fit. Remove the plastic cover over the swan neck Td5 check strap. The strap is held on with 3 bolts. The Wolf one fits in place and aligns with the sliding recess in the door panel. See parts book attachments for the original parts and the Wolf type bits you’ll need. This strap mounts in the same place using the same bolt part numbers. Click image to enlarge Click image to enlarge Click image to enlarge JB @Lodelaner Instagram Youtube greenlaning and other LR related content Last edited by Lodelaner on 31st Dec 2018 9:08am. Edited 1 time in total |
31st Dec 2018 9:02am |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Thanks very much for the quick reply.
So is that the bracket that goes onto the body? Which actuall check strap do we need that goes onto the door? Not sure it might still be fitted, but will need to check. |
31st Dec 2018 9:05am |
[quote="Widget"]You could bodge it (as in the red door). Only joking, just attached that photo to illustrate your dilemma!
However the Wolf check strap will fit. Remove the plastic cover over the swan neck Td5 check strap. The strap is held on with 3 bolts. The Wolf one fits in place and aligns with the sliding recess in the door panel. See parts book attachments for the original parts and the Wolf type bits you’ll need. This strap mounts in the same place using the same bolt part numbers. That’s brilliant info thanks! I think as we have the swan necks still fitted, the bodge you illustrate on the red door is the easy option for us. So will look to get some of those mounts. Thanks again. |
31st Dec 2018 9:09am |
Bracket Assy - Door Check Arm RH - LR020251 - Genuine |
31st Dec 2018 9:12am |
[quote="dorsetsmith"]https://www.lrworkshop.com/diagrams/land-rover-series-3-chassis-body/series-3-doors
series 3 1971 to 1985 / Wolf front Door check strap mounts body end part number 346878 Thanks for the advice, I’ve ordered two of these now. And today remove the existing ones in preparation. Thanks again for all the advice guys. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
1st Jan 2019 1:51pm |
Hi Everyone,
Just wanted to say thanks for the advice given by people on here. We got the new hinge brackets and fitted them to our doors. Click image to enlarge Click image to enlarge Thanks again for all the help. |
18th Jan 2019 10:15am |
