Home > Td5 > Wolf Door - Check Straps
Nigelpugh7
Hi Guys,
Need a bit of help,and guidance here.
Our TD5 is fitted with wolf doors with the sliding top windows.
Only problem is that the door bottoms are not fitted with any door checkstraps, which is becoming a pain.
The original door checkstrap mounts are still fitted to the chassis in the original locations, and the swan neck ( or S shape?) but as they don’t fit the wolf doors they were. Just rattling about so we took them out.
Can I just purchase wolf door checkstraps and for those? If so what part number do I need and where would we get them from.
Seems the real issues is that the check strap mounting position is not at the same height on the body as it is on the wolf doors?
Anyone got any bright ideas?
Thanks in advance,
Post #748186 31st Dec 2018 8:19am
dorsetsmith
https://www.lrworkshop.com/diagrams/land-r...es-3-doors
series 3 1971 to 1985 / Wolf front Door check strap mounts body end
part number 346878
TD5 1998 to 2006 original door check strap mounts door end
Bracket Assy - Door Check Arm LH - BDU710150 - Genuine
Bracket Assy - Door Check Arm RH - LR020251 - Genuine
Post #748195 31st Dec 2018 8:45am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
You could bodge it using the series 3 items above - as shown on the red door. Only joking, just attached that photo to illustrate your dilemma! Also if you have door cards they’ll won’t fit or need cutting to adapt.
However the Wolf check strap will fit. Remove the plastic cover over the swan neck Td5 check strap. The strap is held on with 3 bolts. The Wolf one fits in place and aligns with the sliding recess in the door panel.
See parts book attachments for the original parts and the Wolf type bits you’ll need. This strap mounts in the same place using the same bolt part numbers.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #748198 31st Dec 2018 9:02am
Nigelpugh7
Thanks very much for the quick reply.
So is that the bracket that goes onto the body?
Which actuall check strap do we need that goes onto the door?
Not sure it might still be fitted, but will need to check.
Post #748199 31st Dec 2018 9:05am
Nigelpugh7
[quote="Widget"]You could bodge it (as in the red door). Only joking, just attached that photo to illustrate your dilemma!
That’s brilliant info thanks!
I think as we have the swan necks still fitted, the bodge you illustrate on the red door is the easy option for us.
So will look to get some of those mounts.
Thanks again.
Post #748201 31st Dec 2018 9:09am
dorsetsmith
Post #748203 31st Dec 2018 9:12am
Nigelpugh7
[quote="dorsetsmith"]https://www.lrworkshop.com/diagrams/land-rover-series-3-chassis-body/series-3-doors
part number 346878
Thanks for the advice, I’ve ordered two of these now.
And today remove the existing ones in preparation.
Thanks again for all the advice guys.
Post #748472 1st Jan 2019 1:51pm
Nigelpugh7
Thanks for the info
Hi Everyone,
Just wanted to say thanks for the advice given by people on here.
We got the new hinge brackets and fitted them to our doors.
Thanks again for all the help.
Post #752067 18th Jan 2019 10:15am
