Home > Puma (Tdci) > Fitting Mantec Steering Guard to Puma defender
Page 2 of 4 <1234>
BigMike
110SEB wrote:
...except after this early morning moan, I realise that QT don't appear to make a steering guard.
Shame about the imperfect experience some have had with Mantec though.
What are people's experiences of fitting OEM? I have the cheapo Rebel 4x4 job and although not up there with the top quality guards, it was cheap, easy to fit, built like a tank and has saved my steering on several occasions.
I have an OEM bar, bought it from ebay, cost a tenner. I don't like snowplough style guards. if you need to be pulled out of the s&^% backwards and you're in deep all it does is force the mud/snow/sand/whatever up into the engine bay. I take mine green laning all the time and it's ideal, plus it doesn't weigh much either. Have given it a knock or two as well and it's very robust. Four bolts, one of which is already in there anyway. Takes about half an hour to fit.
Out of interest, how many people who fit steering guards have retained the side steps?
Post #71016 15th May 2011 5:00pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Fitted my Mantec tonight bit of pain to do and I have some bits left Shocked But it's not going anywhere looks Cool In black powder coat.
Post #81458 21st Jul 2011 8:28pm
LR90XS2011
Has anyone fitted one of the Cor4 ones Andy from Alive was selling
if so did you have any problems DEFENDER 90 TDCI XS,
Post #81460 21st Jul 2011 8:41pm
galawaygreen
2010 Defender 90 Puma 2.4 XS CSW Galway Green
i fitted the cor4, got it from LRS at billing went on in 30mins very easy and looks fine.
didnt need any instructions as straight forward.
Post #81469 21st Jul 2011 9:32pm
dgardel
Italy
Remember, I'm LHD your is mirrored Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #81470 21st Jul 2011 9:33pm
dgardel
Italy
Photos?........... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #81475 21st Jul 2011 9:39pm
mick
The Mantec one is easy to fit it's the 2 top bolts that are a pig I left the drivers side top out the other side was bad enough Thumbs Up
Post #81478 21st Jul 2011 9:40pm
mick
Is that the land rover one DG.
Post #81481 21st Jul 2011 9:46pm
galawaygreen
Photos?...........
will do but its dark outside !!
Post #81482 21st Jul 2011 9:49pm
LR90XS2011
Galway Green
Thanks for the info I think I am going COR4 as well
just need to watch out that our cars dont end up looking like twins
all the best Rob DEFENDER 90 TDCI XS,
Post #81519 22nd Jul 2011 7:09am
galawaygreen
LR90XS2011 wrote:
Galway Green
all the best Rob
My wife thinks there all the same, the billing show was somewhat of a mystery to her
"loads of blokes looking at identical cars" Neutral
Post #81524 22nd Jul 2011 8:18am
LR90XS2011
not taken my wife to a show yet Stoneleigh will be her first, just up the road from me DEFENDER 90 TDCI XS,
Post #81588 22nd Jul 2011 7:07pm
dgardel
Italy
Is the same only the external plate is "shaped"
And it is build from Mantec Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #81611 22nd Jul 2011 10:39pm
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all...
I picked up one of these from the Billng show, at the Mantec stand, and I'm about to attempt to install it on my 110. However I have a few questions as well! The instructions are a bit cryptic. I admit that I'm mechanically a beginner, but the instructions just seem a bit confusing.
- For example, they're split down the middle - with a black arrow and "1999" pointing to the right. Am I to assume that, as my vehicle is post 1999, that I'm to follow the steps on the right side of the page?
- Also - they're is one step, when you are removing the factory bolts, that shows a hand ostensibly twisting a bolt. Is that Mantec's way of saying "hand tighten"?
- Red-dot mentioned he fitted it w/o the aluminium plate first. Do the bolts that hold to plate need to be torqued to a particular setting - do do you just tighten them up as much as you can?
- Last but not least... when it comes to removing the grill - my screws are covered by black caps. Do they just pop off? I've been reluctant to remove them in case there is another way of removing them.
Post #81775 24th Jul 2011 1:56pm
mse
Having fitted a few steering guards - nothing should require instructions.
Loosely connect the bolts (Bracket to guard) and offer it up to give you an idea of inside/outside the chassis etc.
Then unbolt, connecting each side in the appropriate holes (you shouldnt be able to miss them) dont tighten anything at this stage
Fit the plate and then do everything up hand tight until its all in place.
You didnt forget to waxoyl any covered sections did you...
then bolt up tight - job done.
Hope you dont find the steering bolt rusting like i did mine. Mike
Post #81785 24th Jul 2011 3:49pm
Page 2 of 4 <1234>
