![]() | Home > Puma (Tdci) > Fitting Mantec Steering Guard to Puma defender |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Fitted my Mantec tonight bit of pain to do and I have some bits left
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
Has anyone fitted one of the Cor4 ones Andy from Alive was selling
if so did you have any problems DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
galawaygreen Member Since: 16 May 2011 Location: Lincolnshire Posts: 132 ![]() ![]() |
i fitted the cor4, got it from LRS at billing went on in 30mins very easy and looks fine. didnt need any instructions as straight forward. |
![]() Click image to enlarge Remember, I'm LHD your is mirrored ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Photos?........... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
The Mantec one is easy to fit it's the 2 top bolts that are a pig I left the drivers side top out the other side was bad enough
Is that the land rover one DG.
will do but its dark outside !! |
Galway Green
Thanks for the info I think I am going COR4 as well just need to watch out that our cars dont end up looking like twins all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
My wife thinks there all the same, the billing show was somewhat of a mystery to her "loads of blokes looking at identical cars" ![]() |
not taken my wife to a show yet Stoneleigh will be her first, just up the road from me DEFENDER 90 TDCI XS,
Is the same only the external plate is "shaped" And it is build from Mantec Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Hi all...
I picked up one of these from the Billng show, at the Mantec stand, and I'm about to attempt to install it on my 110. However I have a few questions as well! The instructions are a bit cryptic. I admit that I'm mechanically a beginner, but the instructions just seem a bit confusing. - For example, they're split down the middle - with a black arrow and "1999" pointing to the right. Am I to assume that, as my vehicle is post 1999, that I'm to follow the steps on the right side of the page? - Also - they're is one step, when you are removing the factory bolts, that shows a hand ostensibly twisting a bolt. Is that Mantec's way of saying "hand tighten"? - Red-dot mentioned he fitted it w/o the aluminium plate first. Do the bolts that hold to plate need to be torqued to a particular setting - do do you just tighten them up as much as you can? - Last but not least... when it comes to removing the grill - my screws are covered by black caps. Do they just pop off? I've been reluctant to remove them in case there is another way of removing them. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Having fitted a few steering guards - nothing should require instructions.
Loosely connect the bolts (Bracket to guard) and offer it up to give you an idea of inside/outside the chassis etc. Then unbolt, connecting each side in the appropriate holes (you shouldnt be able to miss them) dont tighten anything at this stage Fit the plate and then do everything up hand tight until its all in place. You didnt forget to waxoyl any covered sections did you... then bolt up tight - job done. Hope you dont find the steering bolt rusting like i did mine. Mike |
