Home > Maintenance & Modifications > ARB retrofit choice
rallysteve
ARB retrofit choice
Afternoon all,
I would like to retrofit ARBs to my 02' DCPU. There are three choices of routes I can see:
1. Buy all genuine/OE parts - Too expensive
2. Buy one of the Britpart branded kits accepting that the rubber parts and balljoints will probably wear out before I have finished fitting.
3. Buy a secondhand set and just buy new parts as required.
Am i right in thinking 110s, 90s and Discoverys all share the same thickness/stiffness bars?
What do people recommend. 02' 110 TD5 Double Cab Rebuild Thread
Post #744971 10th Dec 2018 3:54pm
jst
4. By a performance handling kit - JE Eng etc
Personally i go with 3. and get some take offs. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #745020 10th Dec 2018 7:52pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Buy take off parts, you should be able to get some good condition bars for sensible money
Post #745021 10th Dec 2018 7:58pm
bankz5152
Been considering the same. Trying to work out if it is worth doing with a 2" lift.
I was going to buy second hand/ britpart ones and fit new quality bushes
Post #745031 10th Dec 2018 8:31pm
rallysteve
I got a set on ebay for just over £100 delivered in the end.
Should be here next week.
Post #745607 13th Dec 2018 9:40pm
WindyJ
Selling a standard rear 90 arb if interested...
Post #745608 13th Dec 2018 9:42pm
I fitted standard (pre-owned take-off) f&r anti-roll bars to my '07 DC and it has made a big difference. I am usually laden to around 2 to 2.5 tonnes, and have a heavy expedition rack, and cornering is now far less uncomfortable.
Post #745627 14th Dec 2018 12:17am
barbel jim
Take offs Thumbs Up
ebay is your friend. The rears are different on a 90 to 110 as is the mounting position.
Post #745673 14th Dec 2018 1:34pm
rallysteve
Jim,
Any ideas on the difference in the rear bar, seems to be the same part number.
I know the clamps and bushes are different on the 110.
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #745677 14th Dec 2018 3:09pm
barbel jim
Sorry for the confusion Embarassed ,the clamps,bushes and mounting positions are the difference I was meant, although iirc there is also a military/HD version which is thicker like a lot of the updated versions at 28mm??
Post #745687 14th Dec 2018 5:09pm
Moneypit
As i understand it, rear 110 bracket has four bolts front and 90's are 2 bolt. There is a heavy duty WMIK rear bar but I don't know the thickness.
Post #745690 14th Dec 2018 5:25pm
