|  | Home > Maintenance & Modifications > ARB retrofit choice |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243      |
 Afternoon all,
 I would like to retrofit ARBs to my 02' DCPU. There are three choices of routes I can see: 1. Buy all genuine/OE parts - Too expensive 2. Buy one of the Britpart branded kits accepting that the rubber parts and balljoints will probably wear out before I have finished fitting. 3. Buy a secondhand set and just buy new parts as required. Am i right in thinking 110s, 90s and Discoverys all share the same thickness/stiffness bars? What do people recommend. 02' 110 TD5 Double Cab Rebuild Thread | ||
|  10th Dec 2018 2:54pm |
| Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271    | Buy take off parts, you should be able to get some good condition bars for sensible money | ||
|  10th Dec 2018 6:58pm |
| bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2239      | Been considering the same. Trying to work out if it is worth doing with a 2" lift.
 I was going to buy second hand/ britpart ones and fit new quality bushes | ||
|  10th Dec 2018 7:31pm |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243      | I got a set on ebay for just over £100 delivered in the end.
 Should be here next week. Steve 02' 110 TD5 Double Cab Rebuild Thread | ||
|  13th Dec 2018 8:40pm |
| WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190  | Selling a standard rear 90 arb if interested... | ||
|  13th Dec 2018 8:42pm |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18056      | I fitted standard (pre-owned take-off) f&r anti-roll bars to my '07 DC and it has made a big difference. I am usually laden to around 2 to 2.5 tonnes, and have a heavy expedition rack, and cornering is now far less uncomfortable. | ||
|  13th Dec 2018 11:17pm |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1459      | Take offs    ebay is your friend. The rears are different on a 90 to 110 as is the mounting position. | ||
|  14th Dec 2018 12:34pm |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243      | Jim,
 Any ideas on the difference in the rear bar, seems to be the same part number. I know the clamps and bushes are different on the 110. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread | ||
|  14th Dec 2018 2:09pm |
| barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1459      | Sorry for the confusion   ,the clamps,bushes and mounting positions are the difference I was meant, although iirc there is also a military/HD version which is thicker like a lot of the updated versions at 28mm?? | ||
|  14th Dec 2018 4:09pm |
| Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271    | As i understand it, rear 110 bracket has four bolts  front and 90's are 2 bolt. There is a heavy duty WMIK rear bar but I don't know the thickness. | ||
|  14th Dec 2018 4:25pm |
| Posting Rules
