![]() | Home > Maintenance & Modifications > ARB retrofit choice |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Afternoon all,
I would like to retrofit ARBs to my 02' DCPU. There are three choices of routes I can see: 1. Buy all genuine/OE parts - Too expensive 2. Buy one of the Britpart branded kits accepting that the rubber parts and balljoints will probably wear out before I have finished fitting. 3. Buy a secondhand set and just buy new parts as required. Am i right in thinking 110s, 90s and Discoverys all share the same thickness/stiffness bars? What do people recommend. 02' 110 TD5 Double Cab Rebuild Thread |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
Buy take off parts, you should be able to get some good condition bars for sensible money
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
Been considering the same. Trying to work out if it is worth doing with a 2" lift.
I was going to buy second hand/ britpart ones and fit new quality bushes |
I got a set on ebay for just over £100 delivered in the end.
Should be here next week. Steve 02' 110 TD5 Double Cab Rebuild Thread |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 ![]() |
Selling a standard rear 90 arb if interested...
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17858 ![]() ![]() ![]() |
I fitted standard (pre-owned take-off) f&r anti-roll bars to my '07 DC and it has made a big difference. I am usually laden to around 2 to 2.5 tonnes, and have a heavy expedition rack, and cornering is now far less uncomfortable.
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1450 ![]() ![]() ![]() |
Take offs
![]() ebay is your friend. The rears are different on a 90 to 110 as is the mounting position. |
Jim,
Any ideas on the difference in the rear bar, seems to be the same part number. I know the clamps and bushes are different on the 110. Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread |
Sorry for the confusion
As i understand it, rear 110 bracket has four bolts front and 90's are 2 bolt. There is a heavy duty WMIK rear bar but I don't know the thickness.
