Home > Technical > Floor mounted seat belt bracket - Defender
Timbo66
United Kingdom 2008 Defender 90 Puma 2.4 CSW Java Black
Hi,
I am in the process of changing the floor mounted seat belt bracket in the rear of my defender. It is the one that is mounted in the centre of the rear floor near to the tailgate. The old was rusted up. It is held on with two bolts, one 10mm and one 17mm and I had assumed that they had some form of captive nuts on the back, but they didn't!! The back has some form of bracket that has fell away.
I can't see how to get at it other than dropping the fuel tank. Sounds a world of pain for two bolts.
Does anyone have any suggestions on how to get at it /how big a job it is to lower the tank?
Thanks
Tim.
Post #741236 19th Nov 2018 1:22pm
NickMc
Picture speaks a thousand words! You don’t say if it’s a 90/110/130 or Td5 tdci?!
Post #741288 19th Nov 2018 7:17pm
I'd hazard a guess that it's a 2008 90 CSW in Java Black Whistle
Tim, I think you're stuck with having to drop the tank. Darren
Post #741291 19th Nov 2018 7:36pm
jst
Magnet on a stick down through one of the bolt holes to locate it and lift it up, get one bolt in the other hole then to hold it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #741310 19th Nov 2018 8:29pm
Timbo66
Thank you.
Thanks you both for the suggestions. I’ll try the magnet route first before dropping the tank.
NickMc - it is a 90. Does this help with your reply/suggestions?
Post #741376 19th Nov 2018 11:00pm
landy andy
If it has the nuts on the plate, use a bit of threaded bar. That way you can slot over the fitting, then use other bolt, remove threaded bar, use second bolt.
Post #741379 19th Nov 2018 11:19pm
Timbo66
Thanks for that, I'll give it a try tonight!!
Post #741444 20th Nov 2018 12:48pm
Rkcorry
No more help than the guys above, fishing with a threaded bar being a top tip.
perhaps the image may be of some help
Post #741580 21st Nov 2018 1:27pm
landy andy
Thumbs Up Thumbs Up
Post #741657 21st Nov 2018 8:54pm
Timbo66
Sadly neither the magnet nor the threaded bar worked Big Cry
Started to remove the cradle to get a chance at getting to it from beneath. 5 broken nuts later from underneath I’m left with the two nuts in the rear bumper area. Normal socket won’t fit, so I need s deep socket. Does anyone know the nut size?
Thanks
Post #742424 26th Nov 2018 8:23pm
Timbo66
All sorted
Thanks for the advice all.
Post #754087 26th Jan 2019 3:40pm
