![]() | Home > Technical > Floor mounted seat belt bracket - Defender |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
Picture speaks a thousand words! You don’t say if it’s a 90/110/130 or Td5 tdci?!
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I'd hazard a guess that it's a 2008 90 CSW in Java Black
Tim, I think you're stuck with having to drop the tank. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8484
Magnet on a stick down through one of the bolt holes to locate it and lift it up, get one bolt in the other hole then to hold it. Cheers
| Timbo66 Member Since: 14 Oct 2018 Location: Leicester Posts: 37
Thanks you both for the suggestions. I’ll try the magnet route first before dropping the tank.
NickMc - it is a 90. Does this help with your reply/suggestions? |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
If it has the nuts on the plate, use a bit of threaded bar. That way you can slot over the fitting, then use other bolt, remove threaded bar, use second bolt.
Thanks for that, I'll give it a try tonight!!
| Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 |
No more help than the guys above, fishing with a threaded bar being a top tip.
perhaps the image may be of some help |
Sadly neither the magnet nor the threaded bar worked
Started to remove the cradle to get a chance at getting to it from beneath. 5 broken nuts later from underneath I’m left with the two nuts in the rear bumper area. Normal socket won’t fit, so I need s deep socket. Does anyone know the nut size? Thanks |
All sorted
Thanks for the advice all. |
