Home > Td5 > Play in gear lever?
lightning
Play in gear lever?
The gear lever (on my 2005 TD5) has about two inches of side to side play when in fifth gear.
In the other gears there’s only a half inch of play.
Fifth gear does work fine, but is it normal to have this much play in the lever? It’s done 105,000 miles.
Post #740527 14th Nov 2018 6:48pm
4RF RDS
Check this and adjust first.
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #740536 14th Nov 2018 7:35pm
gilarion
Usually, it is the bias springs that have weakened and need adjustment also it might be worth checking the NYLON CUP that the gear lever sits in for wear as well. To adjust try putting the gear lever first in third and then loosen the lock nuts and adjust one of the two bolts until all play has been removed. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #740537 14th Nov 2018 7:55pm
lightning
Thanks for the information l adjusted the bias springs a while ago to stop the lever vibrating at certain RPM. That’s all fine now except for fifth gear.
Is the nylon cup easy enough to replace and could it wear in a way that only affects fifth gear?
Post #740550 14th Nov 2018 8:35pm
4RF RDS
To answer the question about the plastic bushing (cup) yes it could cause the play though, not likely as much as you describe. Its intent of that item is to diminish vibration and rattling. 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #740558 14th Nov 2018 8:52pm
4RF RDS
Maybe worth a disassembly and look for wear and tightness of all linkages, screws and pins etc. Especially the grub screw (item 16). The shift tower also wears out on high mileage vehicles and would require replacing.
Good luck. .
1967 MGB GT
Post #740560 14th Nov 2018 9:01pm
grafty99
Also the slots in the turret itself can wear Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #740585 14th Nov 2018 10:37pm
4RF RDS
Like I said... the shift turret (item number 1)wears out on high mileage vehicles. Whistle Laughing 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #740597 14th Nov 2018 11:06pm
lightning
OK thanks l will get on to that.
I assume that it’s a fairly easy job to replace the shift turret, if needed?
Post #740598 14th Nov 2018 11:09pm
4RF RDS
Yup Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #740602 14th Nov 2018 11:15pm
Harry.O
Lovely and simple, pull the gaiter off, remove the gear stick, there's a fiddly smaller gaiter covering the bias springs which needs lifting then undo the 4 bolts holding the turret on and lift it off. There's a video on youtube about how to transfer the springs to a new turret but it's easy. Throw some grease in there whilst apart.
Well worth checking the grub screw #16 shown in the pic that 4RF RDS posted. I fitted a new turret to a recon gearbox almost 2 years ago then earlier this year i lost all gears apart from 3rd. Turned out there was no Loctite on the grub screw and it had worked loose. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #740617 15th Nov 2018 6:31am
Naks
if you have some spare cash lying around, I highly recommend you fit a Slickshift Thumbs Up
https://www.onlinegearboxparts.com/product...lickshift/
Post #740624 15th Nov 2018 7:39am
4RF RDS
Second the recommendation to install a slick shift. One of the best mods you can make to your Defrnder Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #740676 15th Nov 2018 2:44pm
ashtrans
Site Sponsor
Hi,
check 16 is tight but its item 22 that governs how far the lever moves to the right to get 5th Dave
Post #740734 15th Nov 2018 9:20pm
lightning
So that can be adjusted by the look of it.
I might try that, as it’s only fifth gear the rest are OK.
Post #740744 15th Nov 2018 10:00pm
