![]() | Home > Td5 > Play in gear lever? |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Check this and adjust first.
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5130 ![]() ![]() ![]() |
Usually, it is the bias springs that have weakened and need adjustment also it might be worth checking the NYLON CUP that the gear lever sits in for wear as well. To adjust try putting the gear lever first in third and then loosen the lock nuts and adjust one of the two bolts until all play has been removed. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3247 ![]() ![]() |
Thanks for the information l adjusted the bias springs a while ago to stop the lever vibrating at certain RPM. That’s all fine now except for fifth gear.
Is the nylon cup easy enough to replace and could it wear in a way that only affects fifth gear? |
To answer the question about the plastic bushing (cup) yes it could cause the play though, not likely as much as you describe. Its intent of that item is to diminish vibration and rattling. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
Maybe worth a disassembly and look for wear and tightness of all linkages, screws and pins etc. Especially the grub screw (item 16). The shift tower also wears out on high mileage vehicles and would require replacing.
Good luck. . ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Also the slots in the turret itself can wear
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Like I said... the shift turret (item number 1)wears out on high mileage vehicles.
![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
OK thanks l will get on to that.
I assume that it’s a fairly easy job to replace the shift turret, if needed? |
Yup
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
Lovely and simple, pull the gaiter off, remove the gear stick, there's a fiddly smaller gaiter covering the bias springs which needs lifting then undo the 4 bolts holding the turret on and lift it off. There's a video on youtube about how to transfer the springs to a new turret but it's easy. Throw some grease in there whilst apart.
Well worth checking the grub screw #16 shown in the pic that 4RF RDS posted. I fitted a new turret to a recon gearbox almost 2 years ago then earlier this year i lost all gears apart from 3rd. Turned out there was no Loctite on the grub screw and it had worked loose. 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
if you have some spare cash lying around, I highly recommend you fit a Slickshift
![]() https://www.onlinegearboxparts.com/product...lickshift/ -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Second the recommendation to install a slick shift. One of the best mods you can make to your Defrnder
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 263 ![]() ![]() |
Hi,
check 16 is tight but its item 22 that governs how far the lever moves to the right to get 5th Dave |
So that can be adjusted by the look of it.
I might try that, as it’s only fifth gear the rest are OK. |
