Home > Technical > Blown Damper
Grenadier
Blown Damper
Noticed a screeching sound over the past couple of days. Looked under the chassis and found a hydraulic fluid explosion (ahem Whistle ) from the DS Rear Shock. As such the exhaust hanger has been scratching on the prop-shaft every time I went round a roundabout, (opposite to UK, so all pressure on the rear right corner), or up a twisty hill. Need to get the shock replaced asap. I assume general consensus would be, much like tyres, to change the rear as a pair if not all four? 65k vehicle.... Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #739524 9th Nov 2018 3:20pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I believe it is best to replace in axle sets like brake pads. So yes do both rears. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #739527 9th Nov 2018 3:25pm
dorsetsmith
Post #739530 9th Nov 2018 3:30pm
Grenadier
Thanks Phil, thought as much.
Dorsetsmith, thank you, but I think this will be a good excuse to go Bilstein Thumbs Up Monsieur Le Grenadier
Post #739553 9th Nov 2018 5:37pm
Grenadier
Does anyone have a list or know how many bushes I need to get for a complete suspension change? Is it two (upper and lower) per shock? As per OP, rear shock gone, going to take advantage and change all four corners. Following forum advice, going for OE bushes. Thumbs Up Monsieur Le Grenadier
Post #740098 12th Nov 2018 7:07pm
htb2
Wales
4 per corner. if you are changing the shock the replacement will come with new bushes.
Post #740122 12th Nov 2018 7:47pm
Each rear shock has three bushes, a single big one at the top, and two slimmer ones at the bottom.
Post #740128 12th Nov 2018 8:01pm
htb2
Wales
Apologies forgot age of his vehicle was thinking of early R/R and 90/110's that I run which have twin bushes at the top
Post #740137 12th Nov 2018 8:11pm
Procta
If budget is good, I would even change the fronts too. With new bushes Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #740153 12th Nov 2018 8:39pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Yep change the lot at once.
I reckon bilsteins are pound for pound one of the best mods you can do to a Defender.
Post #740156 12th Nov 2018 8:44pm
NickMc
Just a warning make sure you have the right bushes and washers, some of the aftermarket are supplied with ones that don’t suit the later “Bush cup”. I think sometimes the pin ends aren’t quite right either. The 02 on lower shock bushes just don’t last. You can chop of the bush cup, but I’m not sure that helps either. Seen a lot of wallered out shock pin holes on Td5 axles.
Post #740187 12th Nov 2018 9:48pm
NickMc
Do you think they changed this bottom set-up because they wear out so bad? Seems to last longer with the 2 cup style bushes in the bottom.
Post #740190 12th Nov 2018 9:51pm
