![]() | Home > Technical > Blown Damper |
Noticed a screeching sound over the past couple of days. Looked under the chassis and found a hydraulic fluid explosion (ahem
![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Thanks Phil, thought as much.
Dorsetsmith, thank you, but I think this will be a good excuse to go Bilstein ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Does anyone have a list or know how many bushes I need to get for a complete suspension change? Is it two (upper and lower) per shock? As per OP, rear shock gone, going to take advantage and change all four corners. Following forum advice, going for OE bushes.
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
4 per corner. if you are changing the shock the replacement will come with new bushes.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17877 ![]() ![]() ![]() |
Each rear shock has three bushes, a single big one at the top, and two slimmer ones at the bottom.
Apologies forgot age of his vehicle was thinking of early R/R and 90/110's that I run which have twin bushes at the top
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5331 ![]() ![]() |
If budget is good, I would even change the fronts too. With new bushes ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Yep change the lot at once.
I reckon bilsteins are pound for pound one of the best mods you can do to a Defender. |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Just a warning make sure you have the right bushes and washers, some of the aftermarket are supplied with ones that don’t suit the later “Bush cup”. I think sometimes the pin ends aren’t quite right either. The 02 on lower shock bushes just don’t last. You can chop of the bush cup, but I’m not sure that helps either. Seen a lot of wallered out shock pin holes on Td5 axles.
Do you think they changed this bottom set-up because they wear out so bad? Seems to last longer with the 2 cup style bushes in the bottom. |
