![]() | Home > Maintenance & Modifications > Drive belt part number |
2.2 with aircon uses LR031360.
Puma aux belts have a 10 year change interval, but doesn't hurt to change them early. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I can get the number from mine later on,
It’s this long! ![]() ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20895 ![]() ![]() |
I use be wrong and maybe only the 2.4 but I think 55k also springs to mind, I don't know why but I think that's what I read up and approx when I changed mine. I was getting a bit of squeak on start up, since changing it's been perfect. They aren't as hard to change over as you might imagine either, you can do them yourself no problem. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3495 ![]() ![]() ![]() |
Thanks all. Took it off for final BAS hose fitment and wasn’t looking all that fresh after 6yrs! 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
Mine snapped after it got soaked it oil from the leaking injector seals.
But I fitted it with the fan in situ, it wasn't difficult. It would be really easy if you have the locking tool to take the fan off. |
