![]() | Home > Maintenance & Modifications > Drive belt part number |
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
2.2 with aircon uses LR031360.
Puma aux belts have a 10 year change interval, but doesn't hurt to change them early. |
| ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127
I can get the number from mine later on,
It’s this long! Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
I use be wrong and maybe only the 2.4 but I think 55k also springs to mind, I don't know why but I think that's what I read up and approx when I changed mine. I was getting a bit of squeak on start up, since changing it's been perfect. They aren't as hard to change over as you might imagine either, you can do them yourself no problem. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502
Thanks all. Took it off for final BAS hose fitment and wasn’t looking all that fresh after 6yrs! 1951 80" S1 2.0
Mine snapped after it got soaked it oil from the leaking injector seals.
But I fitted it with the fan in situ, it wasn't difficult. It would be really easy if you have the locking tool to take the fan off. |
