![]() | Home > Maintenance & Modifications > Puma clutch lube! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20983 ![]() ![]() |
What lube did you use lithium? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 ![]() ![]() |
I first tried a spray called tri-flow a few weeks ago then today gave about six pumps of general grease from the gun.
Borrowed a grease nipple from the other defenders trackrod for two mins. The grease is nothing special just the same stuff i put in the props etc |
Lithium then general purpose most likely. Will have to take a look shortly! The screws on the cover plate benefit from ACF50 occasionally too. Thanks for reminding me 👍🏻 ____\We|Will|Win/___
Jim1988 Member Since: 26 Oct 2017 Location: Derbyshire Posts: 274 ![]() ![]() |
I would be interested in a how to if you do have the photos ☺️ Thanks Jim.
Ill take some tomorrow and a bit of step by step.
Steve you reminded me too that my next job is to start the mega task of corrosion prevention! |
Cheers pal, I’m on a bit of a grease mission at the minute, and do have a creaky clutch Thanks Jim.
Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71 ![]() ![]() ![]() |
I cured my clutch pedal creak by greasing the spring where it hooks on the pedal. There’s supposed to be a plastic grommet on there but they disintegrate leaving metal on metal.
