Home > Maintenance & Modifications > Puma clutch lube!
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
Puma clutch lube!
Evening chaps,
You guys are probably aware of this tip already but I greased the cutch master cylinder pivot today!
Only took half hour but an improvement noticed in clutch effort.
Little things add up to a easier drive.
If anyone struggles or fancies a go, let me know and I'll redo it with pics
Regards
Post #713295 19th Jun 2018 9:23pm
What lube did you use lithium? _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #713297 19th Jun 2018 9:26pm
Tommyharris
I first tried a spray called tri-flow a few weeks ago then today gave about six pumps of general grease from the gun.
Borrowed a grease nipple from the other defenders trackrod for two mins.
The grease is nothing special just the same stuff i put in the props etc
Post #713302 19th Jun 2018 9:34pm
Lithium then general purpose most likely. Will have to take a look shortly! The screws on the cover plate benefit from ACF50 occasionally too. Thanks for reminding me 👍🏻 _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #713305 19th Jun 2018 9:36pm
Jim1988
I would be interested in a how to if you do have the photos ☺️ Thanks Jim.
Post #713306 19th Jun 2018 9:38pm
Tommyharris
Ill take some tomorrow and a bit of step by step.
Steve you reminded me too that my next job is to start the mega task of corrosion prevention!
Post #713307 19th Jun 2018 9:41pm
Jim1988
Cheers pal, I’m on a bit of a grease mission at the minute, and do have a creaky clutch Thanks Jim.
Post #713308 19th Jun 2018 9:43pm
Argee
I cured my clutch pedal creak by greasing the spring where it hooks on the pedal. There’s supposed to be a plastic grommet on there but they disintegrate leaving metal on metal.
Post #713312 19th Jun 2018 9:51pm
