Home > Maintenance & Modifications > Puma clutch lube! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19677 |
What lube did you use lithium? Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
19th Jun 2018 9:26pm |
Tommyharris Member Since: 20 Mar 2018 Location: Bristol Posts: 100 |
I first tried a spray called tri-flow a few weeks ago then today gave about six pumps of general grease from the gun.
Borrowed a grease nipple from the other defenders trackrod for two mins. The grease is nothing special just the same stuff i put in the props etc |
19th Jun 2018 9:34pm |
Lithium then general purpose most likely. Will have to take a look shortly! The screws on the cover plate benefit from ACF50 occasionally too. Thanks for reminding me ππ» Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§
19th Jun 2018 9:36pm |
Jim1988 Member Since: 26 Oct 2017 Location: Derbyshire Posts: 208 |
I would be interested in a how to if you do have the photos βΊοΈ
19th Jun 2018 9:38pm |
Ill take some tomorrow and a bit of step by step.
Steve you reminded me too that my next job is to start the mega task of corrosion prevention! |
19th Jun 2018 9:41pm |
Cheers pal, Iβm on a bit of a grease mission at the minute, and do have a creaky clutch
19th Jun 2018 9:43pm |
Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71 |
I cured my clutch pedal creak by greasing the spring where it hooks on the pedal. Thereβs supposed to be a plastic grommet on there but they disintegrate leaving metal on metal.
19th Jun 2018 9:51pm |
