Home > Puma (Tdci) > Puma 110 won't start.
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Hi lads, I'm in a bit of a pickle here- especially with the winters conditions we are having at the moment, my 110 won't start.
When I turn the key nothing happens, the starter relay clicks, the starter itself clicks once but that's all it does. it has no immobiliser, the starter was replaced a few months back along with a new battery which is still putting out max power and clamps are good and tight.. In the past few weeks I've replaced the vacuum pump and gasket as it was leaking and done the injector washers and seals and crack cases seals while I was at it.
It won't start on a jump start but will on a tow start.
Any ideas?
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #689620 28th Feb 2018 3:00pm
Starter solenoid, or starter relay under the o/s/f seat perhaps.
Post #689623 28th Feb 2018 3:11pm
John110
I switched the two black relays around and still no joy! For those who understand, no explanation is needed...
Post #689634 28th Feb 2018 3:25pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Give your starter motor a good few whacks with the back of a ratchet or something metalic and do it a few times . If its a stuck solenoid it may free it temporarily
Post #689639 28th Feb 2018 3:33pm
zsd-puma
Check the earth leads are rust free and tight on the gearbox and chassis.
Clouting the starter while someone cranks the ignition might get it going, in which case it's the starter/solenoid that's kaput.
Have you load tested the battery or just checked the voltage?
Post #689652 28th Feb 2018 4:07pm
dorsetsmith
battery main fuse ok i.e 400 amp one
Post #689660 28th Feb 2018 4:25pm
John110
I gave it a few slaps with a heavy bar but no joy.
I swear it's trying my patience this past few weeks! For those who understand, no explanation is needed...
Post #689661 28th Feb 2018 4:27pm
Huttopia
When you put the key in and turn to position 2 do you wait to hear the relay click? It can be quite a wait. In the past I’ve done it more than once and then fired up no problem. If I didn’t wait the vehicle wouldn’t start for love / money / threats of violence Very Happy
Post #689701 28th Feb 2018 6:42pm
John110
Got a fellow defender driver mate to give me a tow start and drove it up to the yard and put it in the garage and will change it when the weather clears up. We are currently experiencing the worst snow blizzards since 1982 and the whole country is on shutdown.
Trust a Land Rover to let you down at this time. I love them but I'm currently in a dilemma between a reliable mode of transport, or keeping my defender.
Thanks for all the help
Post #690004 1st Mar 2018 4:48pm
jst
Small hammer surely over back of ratchet! i would cry! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #690069 1st Mar 2018 8:14pm
John110
Well I tackled the job yesterday with the help of a fellow defender driver. It ended up being a broken connection on the ignition wire, the loop around the bolt had broken and shorted itself out. After a bit of fiddling and a lot of extensions and knuckle joints we got it redone.
Starting first turn now, delighted but I think I got away lightly!
Post #690858 4th Mar 2018 3:17pm
Bluericky
Great, glad you got it fixed. All the knowledge on this forum couldn’t have got to the bottom of that one !
Post #690859 4th Mar 2018 3:24pm
