![]() | Home > Puma (Tdci) > Puma 110 won't start. |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 ![]() ![]() ![]() |
Hi lads, I'm in a bit of a pickle here- especially with the winters conditions we are having at the moment, my 110 won't start.
When I turn the key nothing happens, the starter relay clicks, the starter itself clicks once but that's all it does. it has no immobiliser, the starter was replaced a few months back along with a new battery which is still putting out max power and clamps are good and tight.. In the past few weeks I've replaced the vacuum pump and gasket as it was leaking and done the injector washers and seals and crack cases seals while I was at it. It won't start on a jump start but will on a tow start. Any ideas? Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17858 ![]() ![]() ![]() |
Starter solenoid, or starter relay under the o/s/f seat perhaps.
I switched the two black relays around and still no joy! For those who understand, no explanation is needed...
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Give your starter motor a good few whacks with the back of a ratchet or something metalic and do it a few times . If its a stuck solenoid it may free it temporarily
battery main fuse ok i.e 400 amp one
I gave it a few slaps with a heavy bar but no joy.
I swear it's trying my patience this past few weeks! For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
When you put the key in and turn to position 2 do you wait to hear the relay click? It can be quite a wait. In the past I’ve done it more than once and then fired up no problem. If I didn’t wait the vehicle wouldn’t start for love / money / threats of violence
Got a fellow defender driver mate to give me a tow start and drove it up to the yard and put it in the garage and will change it when the weather clears up. We are currently experiencing the worst snow blizzards since 1982 and the whole country is on shutdown.
Trust a Land Rover to let you down at this time. I love them but I'm currently in a dilemma between a reliable mode of transport, or keeping my defender. Thanks for all the help John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8322 ![]() ![]() ![]() |
Small hammer surely over back of ratchet! i would cry! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Well I tackled the job yesterday with the help of a fellow defender driver. It ended up being a broken connection on the ignition wire, the loop around the bolt had broken and shorted itself out. After a bit of fiddling and a lot of extensions and knuckle joints we got it redone.
Starting first turn now, delighted but I think I got away lightly! Thanks for all the help Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
Great, glad you got it fixed. All the knowledge on this forum couldn’t have got to the bottom of that one !
