![]() | Home > Puma (Tdci) > Does your Puma make a beeeeep after the EGR self-cleaning? |
| parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366
I've got the egr turned off (BAS tuned) and i can't hear any beeping. 130 crew cab
98 V8 Disco |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935
No Beep- just the chukka-chukka sound. 2010 90 XS
| clutch Member Since: 19 Mar 2011 Location: Cape Town Posts: 8
Workshop Manual, Defender, MY2007- ON
see page 564 of 1212 "The EGR cooler receives exhaust gas ....blabla .... engine operation. At engine switch off the valve opens and closes several times to clear any deposits which may have accumulated during running." Thanks to dgardel for this post http://www.defender2.net/forum/topic5725.html 2x1: KTM 990R, 4x4: Landy 110 |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Yup, we know what the "chukka-chukka" sound is, it's the "beep" that is mystery! |
| ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153
i wonder if this high pitched sound isn't just our ears singing after driving with the window open and our elbow hanging out.... www.ralton.co.za
No, I reckon that's the reason that most people can't hear it! |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
Now that I'm paying more attention, I am also hearing a similar beep when starting the landy. Turn on the ignition and while wait for the glow plug warning light to go out, have a good listen
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173
Mine started to give me this chukka chukka sound after shut down the engine about a month ago and still it happening. Would it stop one day or could it be a fault?
| JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412
Thats quite normal http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
| Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236
I always had this as well, on ignition and after the chukkas x3. Seemed normal to me. Actually it psyches me up to fire up the Landy Flattened |
| Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610
This is the sound of the standard car, with EGR enabled... (Thanks Naks)
http://www.youtube.com/watch?v=AVk-oxSZbNM This is what our EGR shut mod does... Absolutely nothing! http://www.youtube.com/watch?v=yvWjdzKof7U You can hear a short high pitched, servo kind of noise. To be honest, this video was made early on this year, and I cannot remember what i had set the duration to. It's since been set to 50ms and so cannot be heard at all. Last edited by Alive Tuning on 8th Nov 2011 10:27pm. Edited 1 time in total |
I'm a newbie in these sort of things could you please tell me the difference or advantage of having the EGR on/off. Thanks 2012 Fuji White 110 Flattened |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Over here we have no choice but to have an EGR to make the vehicle comply with various emissions legislation. People have had erratic running due to the EGR sooting up . There has been work done to remove the EGR or fit a "blanking plate"to effectively stop it doing it's job. Some say this gives smoother running but your ECU needs to be fooled into thinking that the EGR is still doing it's job. This is the difficult bit. Various experiments have been done with blanking plates with various size holes to get the smallest one possible to fool the ECU into thinking everything is normal. Don't think there is a perfect one yet. If your country does not have the same emissions legislation as us you probably do not need an EGR but if one is fitted to your Puma you are probably stuck with it until someone comes up with a solution for removing it, without getting fault codes etc from the ECU. There will be someone on later with more technical info so stay tuned. 1982 88" 2.25 diesel
I'm sure i can even hear a small "click" at the end of the high pitched beep, like a switch... www.ralton.co.za
