Home > Puma (Tdci) > Does your Puma make a beeeeep after the EGR self-cleaning?
Does your Puma make a 2-3s beep after the EGR self-cleaning cycle?
Yes
27%
 27%  [14]
No
70%
 70%  [36]
Not Applicable
1%
 1%  [1]
Total Votes: 51
Page 3 of 4 <1234>
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
I've got the egr turned off (BAS tuned) and i can't hear any beeping. 130 crew cab
98 V8 Disco
Post #64349 19th Mar 2011 4:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
No Beep- just the chukka-chukka sound. 2010 90 XS
Post #64360 19th Mar 2011 7:49pm
clutch
South Africa 2011 Defender 110 Puma 2.4 SW Stornoway Grey
"chukka-chukka" - to rest!
Workshop Manual, Defender, MY2007- ON
see page 564 of 1212
"The EGR cooler receives exhaust gas ....blabla .... engine operation. At engine switch off the valve opens and closes several times to clear any deposits which may have accumulated during running."
Thanks to dgardel for this post http://www.defender2.net/forum/topic5725.html 2x1: KTM 990R, 4x4: Landy 110
Post #64636 21st Mar 2011 10:53pm
Re: "chukka-chukka" - to rest!
Yup, we know what the "chukka-chukka" sound is, it's the "beep" that is mystery!
Post #64699 22nd Mar 2011 12:55pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I've got to change my plea. It was very quiet for a change tonight when I switched off and I was actually ouside the car and reached in to turn off and remove the key. There is definitely a noise accompanying the chukkas. I don't think it's a beep like you'd get from a speaker or buzzer, it reminds me more of a small high speed servo motor finding its home position.
Pete
Post #64901 24th Mar 2011 12:12am
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
i wonder if this high pitched sound isn't just our ears singing after driving with the window open and our elbow hanging out.... www.ralton.co.za
Post #64912 24th Mar 2011 6:07am
No, I reckon that's the reason that most people can't hear it!
Post #64933 24th Mar 2011 10:15am
Naks
Now that I'm paying more attention, I am also hearing a similar beep when starting the landy. Turn on the ignition and while wait for the glow plug warning light to go out, have a good listen Rolling Eyes --
Post #64934 24th Mar 2011 10:16am
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
Mine started to give me this chukka chukka sound after shut down the engine about a month ago and still it happening. Would it stop one day or could it be a fault? Confused
Post #98797 8th Nov 2011 6:11pm
JSG
Thats quite normal Thumbs Up John
2011 Tdci 110 CSW XS
Post #98805 8th Nov 2011 7:17pm
Def-00
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Fuji White
Naks wrote:
I am also hearing a similar beep when Turn on the ignition
I always had this as well, on ignition and after the chukkas x3. Seemed normal to me. Actually it psyches me up to fire up the Landy Very Happy 2012 Fuji White 110 Flattened
Post #98837 8th Nov 2011 9:13pm
Alive Tuning
This is the sound of the standard car, with EGR enabled... (Thanks Naks) Wink
http://www.youtube.com/watch?v=AVk-oxSZbNM
This is what our EGR shut mod does... Absolutely nothing! Mr. Green
http://www.youtube.com/watch?v=yvWjdzKof7U
You can hear a short high pitched, servo kind of noise. To be honest, this video was made early on this year, and I cannot remember what i had set the duration to. It's since been set to 50ms and so cannot be heard at all.
Post #98851 8th Nov 2011 9:58pm
Def-00
I'm a newbie in these sort of things could you please tell me the difference or advantage of having the EGR on/off. Thanks 2012 Fuji White 110 Flattened
Post #98856 8th Nov 2011 10:12pm
spudfan
Ireland
Over here we have no choice but to have an EGR to make the vehicle comply with various emissions legislation. People have had erratic running due to the EGR sooting up . There has been work done to remove the EGR or fit a "blanking plate"to effectively stop it doing it's job. Some say this gives smoother running but your ECU needs to be fooled into thinking that the EGR is still doing it's job. This is the difficult bit. Various experiments have been done with blanking plates with various size holes to get the smallest one possible to fool the ECU into thinking everything is normal. Don't think there is a perfect one yet. If your country does not have the same emissions legislation as us you probably do not need an EGR but if one is fitted to your Puma you are probably stuck with it until someone comes up with a solution for removing it, without getting fault codes etc from the ECU. There will be someone on later with more technical info so stay tuned. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #98875 9th Nov 2011 12:12am
ralton
I'm sure i can even hear a small "click" at the end of the high pitched beep, like a switch... www.ralton.co.za
Post #99833 14th Nov 2011 11:10am
Page 3 of 4 <1234>
