Home > Puma (Tdci) > Aerial cable
CyberCharlie
United Kingdom 2007 Defender 110 Puma 2.4 USW Java Black
Aerial cable
Hi,
so if this weekend the weather allows me to stay outside for some time, i am planning to replace the crappy standard aerial with a rubbery one (apparently has a much better reception - no idea i trust the shop!)
While removing the antenna should not be a big deal, running the cable back in the dashboard might be complicate. Do you guys have any experience/suggestion that you want to share with me?
I suspect that i'll have to tear the dashboard apart... Crying or Very sad
Post #56695 4th Feb 2011 1:43pm
RED-DOT
Simply remove the radio then cut the coax under the aerial, join some strong string or fishing line to the cut end and pull through to radio end then attatch and tape the new plug and pull through to radio. Saves stripping the dash out to access grommet. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #56698 4th Feb 2011 2:01pm
CyberCharlie
Cheers Thumbs Up
I will try tomorrow.
ciao Very Happy
Post #56700 4th Feb 2011 2:06pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Please could you post some pictures if its not too much to ask. I am interested in replacing my standard ariel with a rubber one due to me traveling in remote locations and reception being very poor. Cheers Thumbs Up '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #56804 4th Feb 2011 10:13pm
mse
I know it doesnt help, but even in some remote scottish places, the radio full retracted has picked up stations perfectly.
The only reason i would replace it is stop it being snapped Mike
Post #56829 5th Feb 2011 12:54am
pom
Wonder if the heated front screen could be used as an aerial bit like in the disco?
Pom
Post #56835 5th Feb 2011 1:08am
Eh Pom it's the rear side windows in the d3 Whistle
Post #56843 5th Feb 2011 7:38am
Glynparry25
And D1 and 2
Glyn Sheep Dog
Post #56856 5th Feb 2011 10:09am
Glynparry25
Yes, and no...... from experience I have fount that the easiest way is to use the old cable to pull the new through. Cut the old one, push the new one into it a lottle bit, then using tape make it so that the cable is the same diamiter all the way along and cover about 12" of each cable so that it soesn't come lose whilst puling through.
Glyn Dog Sheep
Post #56860 5th Feb 2011 10:22am
pom
Yeah I know but I don't have any side windows as they force you to pay insane amounts of tax Thumbs Up
So would have to be the front.
Pom
Post #56894 5th Feb 2011 1:13pm
CyberCharlie
sorry i read your message too late and is already job done.
basically, just pull a string with the old cable, but when it comes to pulling the new cable in, i would advise running a metal wire after the string. gives a much better grip and control of the incoming cable.
replacing the whole thing took a couple of hours as i lost ages in removing the old antenna holder under the wing ( before i realized that it was just locked by a metal clip)
but it was great fun all in all Very Happy
Post #56956 5th Feb 2011 7:10pm
lrdxb110
Cheers Cybercharlie Thumbs Up I'll have a go when I order my rubber antenna. '08 LR Defender 110
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #56962 5th Feb 2011 7:33pm
Lorryman100
CyberCharlie,
How much clearance is there under the wing? Looking to fit a stainless electric aerial but it needs 33cm clearance under the wing. Any idea before I go and rip out the wheel well lining too check?
Cheers.
Post #56964 5th Feb 2011 7:40pm
CyberCharlie
Lorryman100 wrote:
CyberCharlie,
Cheers.
let me fish the old antenna from the rubbish and tomorrow i'll let u know.
cheers Very Happy
Post #56983 5th Feb 2011 8:45pm
CyberCharlie
Lorryman100 wrote:
CyberCharlie,
Cheers.
24 cm, my friend Big Cry
Post #57074 6th Feb 2011 10:31am
