![]() | Home > Puma (Tdci) > Aerial cable |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
There is a bit more clearance under there than the old aerial - but its tight and the ABS modulator doesnt help Mike
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Cheers for that |
cheers Mike, will do the same tomorrow and see if I can get a 33cm aerial in the space
if you open the blanked vent (where the heater intake is the other side) and put your hand in there you will be able to feel the existing and see the space.
My concer would be width than depth - but there seems enough to take an electric as i thought of doing it. For the sake of 6 ish screws - dead easy to check Mike |
| All times are GMT |
