![]() | Home > Puma (Tdci) > Aerial cable |
| CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140
Hi,
so if this weekend the weather allows me to stay outside for some time, i am planning to replace the crappy standard aerial with a rubbery one (apparently has a much better reception - no idea i trust the shop!) While removing the antenna should not be a big deal, running the cable back in the dashboard might be complicate. Do you guys have any experience/suggestion that you want to share with me? I suspect that i'll have to tear the dashboard apart... |
I will try tomorrow. ciao |
| lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224
Please could you post some pictures if its not too much to ask. I am interested in replacing my standard ariel with a rubber one due to me traveling in remote locations and reception being very poor. Cheers
'08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
I know it doesnt help, but even in some remote scottish places, the radio full retracted has picked up stations perfectly.
The only reason i would replace it is stop it being snapped Mike |
| pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
Wonder if the heated front screen could be used as an aerial bit like in the disco?
Pom |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Eh Pom it's the rear side windows in the d3
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
And D1 and 2 Glyn |
Yes, and no...... from experience I have fount that the easiest way is to use the old cable to pull the new through. Cut the old one, push the new one into it a lottle bit, then using tape make it so that the cable is the same diamiter all the way along and cover about 12" of each cable so that it soesn't come lose whilst puling through. Glyn |
Yeah I know but I don't have any side windows as they force you to pay insane amounts of tax So would have to be the front. Pom |
sorry i read your message too late and is already job done. basically, just pull a string with the old cable, but when it comes to pulling the new cable in, i would advise running a metal wire after the string. gives a much better grip and control of the incoming cable. replacing the whole thing took a couple of hours as i lost ages in removing the old antenna holder under the wing ( before i realized that it was just locked by a metal clip) but it was great fun all in all |
Cheers Cybercharlie
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
CyberCharlie,
How much clearance is there under the wing? Looking to fit a stainless electric aerial but it needs 33cm clearance under the wing. Any idea before I go and rip out the wheel well lining too check? Cheers. |
let me fish the old antenna from the rubbish and tomorrow i'll let u know. cheers |
24 cm, my friend |
| All times are GMT |
