Home > In Car Electronics > Puma heater blower, 12v and radio not working
Page 2 of 2 <12
dorsetsmith
Report your finding, Thumbs Up
Post #593917 17th Jan 2017 8:55pm
Martin
Site Admin
All the small type ignition switches supercede to LR039638 and they have two holes.
Maybe LR did the right thing for once and made it easy to change Laughing
I would follow the workshop manual, looks easier than a non-Puma Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #593955 17th Jan 2017 10:18pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Did you get this fixed in the end ? I’m about to order an ignition switch as last night I jumped into the landy soaking wet cranked up the blower and absolutely nothing happened , then the radio stopped . Wiggled key in ignition, radio worked again but the moment i turned on the blower they both stopped . Sounds like a ropey connection on the switch.
Is it just the switch I need and how much of a pain is the job ?
Thanks https://www.instagram.com/hustynminepark/
Post #762673 9th Mar 2019 2:57pm
Martin
Site Admin
https://www.defender2.net/forum/topic56773...ion+switch  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #762889 11th Mar 2019 3:09pm
Bluericky
Hi Martin,
That’s great , thank you. Although I did manage to change the switch without dismantling the steering column. The screws holding the switch in place are not done up at all tight albeit rather awkward to get at . https://www.instagram.com/hustynminepark/
Post #762892 11th Mar 2019 3:34pm
Page 2 of 2 <12
