![]() | Home > In Car Electronics > Puma heater blower, 12v and radio not working |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Report your finding,
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
All the small type ignition switches supercede to LR039638 and they have two holes.
Maybe LR did the right thing for once and made it easy to change I would follow the workshop manual, looks easier than a non-Puma 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647
Did you get this fixed in the end ? I’m about to order an ignition switch as last night I jumped into the landy soaking wet cranked up the blower and absolutely nothing happened , then the radio stopped . Wiggled key in ignition, radio worked again but the moment i turned on the blower they both stopped . Sounds like a ropey connection on the switch.
Is it just the switch I need and how much of a pain is the job ? Thanks https://www.instagram.com/hustynminepark/ |
https://www.defender2.net/forum/topic56773...ion+switch
2015 D90 XS SW |
Hi Martin,
That’s great , thank you. Although I did manage to change the switch without dismantling the steering column. The screws holding the switch in place are not done up at all tight albeit rather awkward to get at . https://www.instagram.com/hustynminepark/ |
