Home > Maintenance & Modifications > Refinishing Chequerplate - Backing/gasket
hank
Generally speaking, is chequerplate backing/gasket material stuck fast to the chequerplate?
My 110 came with silver chequerplate which I intend to remove and refinish black. The type of finish (anodise, powder coat, paint) depends on whether the backing/gasket comes off. If it doesn't then it depends on what the backing/gasket material is made of.
I would like to remove the chequerplate completely but the associated panel damage will be too costly to repair so refinishing black is the best compromise as it will be less prominent against the Stornoway Grey paint.
Perhaps I’d be better off buying new black chequerplate? My concern there is that the fixing holes won’t line up, resulting in more hole drilling and more opportunity for rust.
Are replacement backing/gaskets available?
I realise the answer it to take it off and have a look which I will do at some point but until then, any experience gratefully received…
Post #590627 6th Jan 2017 10:06am
The backing gasket is neoprene, probably 2-3mm thick. It's loose fitted so shouldn't be stuck to the back, although never say never. Even if it is though, it's not an insurmountable problem.
To be honest, your last line really sums it up - take one off and have a look. It's only half a dozen or so bolts or screws.
Buying new chequer plate just to change the colour does sound like overkill. Darren
Post #590632 6th Jan 2017 10:15am
Froglaise
OE plate has the neoprene foam gasket glued to it and free on the panel side. I had same issue, silver plate but wanted black to be less obvious. Unscrewed, refinished and screwed back on, all the time while the gasket stayed complete and attached to the plate.
Post #590634 6th Jan 2017 10:31am
hank
Thanks both.
Does anybody know whether the acids or heat used in anodising or powder coating will destroy the neoprene?
Froglaise how did you refinish yours?
Post #590648 6th Jan 2017 11:09am
Froglaise
For the smaller rear quarter and bumper top parts I used my own DIY powder coating kit I have. I didn't even attempt baking the gaskets, no chance they'd survive that I just scrapped them off and cut some new from same thickness self adhesive neoprene foam from a B&Q type shop over here in France.
For the long sills and wing tops I blasted to get clean (overkill really any degreasing cleaner will do but I had my blaster out for something else) etch-primed then spray coated with black engine block coat enamel paint from a rattle can I bought at a metal finishers down the road. Takes longer to do and dry that way but very hard and durable, at least as good as powder coat. Looks OE. No scratches or marks after 2000 miles motorway, road and off road over Christmas.
Post #590653 6th Jan 2017 11:28am
RED-DOT
Best thing for CP is to dig a hole in acidic soil, place said CP in hole and cover up with acidic soil.
Leave there until forgotten about! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #590654 6th Jan 2017 11:35am
Froglaise
Rolling with laughter
Not so easy to forget about the 34 holes removing it all leaves in the bodywork though!
Post #590655 6th Jan 2017 11:38am
RED-DOT
Dealer speak..... "a no cost option for added lightness". 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #590657 6th Jan 2017 11:47am
miker
Some of us quite like CP you know Wink
Post #590670 6th Jan 2017 12:26pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
+1 Thumbs Up chequer plate Thumbs Up suits a Defender. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #590672 6th Jan 2017 12:40pm
mse
Reasonable chequer plate suits a defender - some people do go CP mad and it just looks wrong..but better to have CP wingtops and Censored wings! Mike
Post #590681 6th Jan 2017 1:56pm
Mo Murphy
The body panels won't rust if you drill more holes, they're made of aluminium 😉
50 Shades of Pennine Grey
Post #590686 6th Jan 2017 2:09pm
mse
I know the ali bits dont rust, but they do get scratched, dented, chipped, bent etc Mike
Post #590688 6th Jan 2017 2:13pm
hank
Mo
Yeah I thought that but some panels attract a magnet where others don't? (off topic sorry)
Post #590708 6th Jan 2017 3:17pm
miker
Hank, which ones? If your defender is late td5 or newer, you'll have galv steel doors...
Post #590711 6th Jan 2017 3:22pm
