Home > Maintenance & Modifications > Refinishing Chequerplate - Backing/gasket
Page 2 of 2 <12
hank
It's a 2.4 TDCi.
It has various holes drilled around the rear end where the previous owner had light guards, bodged tailgate hinges, brackets etc so I have only magnet tested these areas to determine how to approach welding them up prior to painting, but tailgate edges, rear of cab (DCPU) are steel, the rest of the tailgate and tub is alu
Post #590714 6th Jan 2017 3:28pm
landiedave
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Would it be possible to pop rivet the screw holes then apply touch up paint to the rivet heads to blend into the panel colour? or would this just look naff??
Post #591278 8th Jan 2017 2:55pm
hank
Some of the holes are 10mm. Had the alu ones welded yesterday and I'll mod the steel this weekend
Post #591357 8th Jan 2017 7:46pm
dantastic
What's the point of gaskets under checker plate anyway? If you've drilled a bunch of holes in the panel it's f00ked either way so why go through the effort to protect the paint under? You can't ever take the CP off to marvel at the tidy paint, you can't ever go back to stock.
Post #591389 8th Jan 2017 9:04pm
Page 2 of 2 <12
