![]() | Home > Maintenance & Modifications > Refinishing Chequerplate - Backing/gasket |
landiedave Member Since: 14 Mar 2013 Location: Welsh Marches Posts: 60 ![]() ![]() ![]() |
Would it be possible to pop rivet the screw holes then apply touch up paint to the rivet heads to blend into the panel colour? or would this just look naff??
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2347 ![]() ![]() ![]() |
Some of the holes are 10mm. Had the alu ones welded yesterday and I'll mod the steel this weekend
dantastic Member Since: 04 May 2010 Location: London Posts: 367 ![]() ![]() |
What's the point of gaskets under checker plate anyway? If you've drilled a bunch of holes in the panel it's f00ked either way so why go through the effort to protect the paint under? You can't ever take the CP off to marvel at the tidy paint, you can't ever go back to stock.
