![]() | Home > Maintenance & Modifications > Refinishing Chequerplate - Backing/gasket |
The backing gasket is neoprene, probably 2-3mm thick. It's loose fitted so shouldn't be stuck to the back, although never say never. Even if it is though, it's not an insurmountable problem.
To be honest, your last line really sums it up - take one off and have a look. It's only half a dozen or so bolts or screws. Buying new chequer plate just to change the colour does sound like overkill. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 ![]() |
OE plate has the neoprene foam gasket glued to it and free on the panel side. I had same issue, silver plate but wanted black to be less obvious. Unscrewed, refinished and screwed back on, all the time while the gasket stayed complete and attached to the plate.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Thanks both.
Does anybody know whether the acids or heat used in anodising or powder coating will destroy the neoprene? Froglaise how did you refinish yours? |
For the smaller rear quarter and bumper top parts I used my own DIY powder coating kit I have. I didn't even attempt baking the gaskets, no chance they'd survive that I just scrapped them off and cut some new from same thickness self adhesive neoprene foam from a B&Q type shop over here in France.
For the long sills and wing tops I blasted to get clean (overkill really any degreasing cleaner will do but I had my blaster out for something else) etch-primed then spray coated with black engine block coat enamel paint from a rattle can I bought at a metal finishers down the road. Takes longer to do and dry that way but very hard and durable, at least as good as powder coat. Looks OE. No scratches or marks after 2000 miles motorway, road and off road over Christmas. |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Best thing for CP is to dig a hole in acidic soil, place said CP in hole and cover up with acidic soil.
Leave there until forgotten about! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
![]() Not so easy to forget about the 34 holes removing it all leaves in the bodywork though! |
Dealer speak..... "a no cost option for added lightness". 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Some of us quite like CP you know ![]() |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
+1
![]() ![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Reasonable chequer plate suits a defender - some people do go CP mad and it just looks wrong..but better to have CP wingtops and
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378 ![]() ![]() ![]() |
The body panels won't rust if you drill more holes, they're made of aluminium 😉
I know the ali bits dont rust, but they do get scratched, dented, chipped, bent etc Mike
Yeah I thought that but some panels attract a magnet where others don't? (off topic sorry) Last edited by hank on 6th Jan 2017 3:32pm. Edited 1 time in total |
Hank, which ones? If your defender is late td5 or newer, you'll have galv steel doors...
