![]() | Home > Maintenance & Modifications > Sound insulation for the doors |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Hello,
Has anyone done sound insulation for the doors ? How many meters do I need or the quantity ? 2016 Defender 90 Adventure Edition |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 ![]() |
i used 1 1/2 sheets of 18x32 dynamat DON'T PANIC
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
How did you get it behind there? I'm assuming fit it in then remove the backing tape stuff in situ?
Ordered these can't wait to install them, hate the sound of the door when it shuts and want more noise insulation. 2016 Defender 90 Adventure Edition |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i've done all below window height apart from my doors so i will be interested to hear if it makes a difference and what you do
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3862 ![]() ![]() |
Hello
The silent coat is easy to work with ![]() I removed the backing sheet and then you can move it into place before you actually push it down. I used a decorating roller for that part. Its tacky but until you push it down it allows movement. |
did you also add any foam sheeting on the inside of the door card?
Hello
I didn't but might do as I have done in the back and under seats, ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge All helps in my book ![]() |
