|  | Home > Maintenance & Modifications > Sound insulation for the doors |
| SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464    |
 Hello,
 Has anyone done sound insulation for the doors ? How many meters do I need or the quantity ? 2016 Defender 90 Adventure Edition | ||
|  1st Sep 2016 5:07pm |
| DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412  | i used 1 1/2 sheets of 18x32 dynamat DON'T PANIC | ||
|  1st Sep 2016 7:51pm |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21044    | How did you get it behind there? I'm assuming fit it in then remove the backing tape stuff in situ? | ||
|  1st Sep 2016 8:01pm |
 Ordered these can't wait to install them, hate the sound of the door when it shuts and want more noise insulation. 2016 Defender 90 Adventure Edition | ||
|  3rd Sep 2016 10:33am |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189      | i've done all below window height apart from my doors so i will be interested to hear if it makes a difference and what you do | ||
|  3rd Sep 2016 7:33pm |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3898    | Hello
 The silent coat is easy to work with   I removed the backing sheet and then you can move it into place before you actually push it down. I used a decorating roller for that part. Its tacky but until you push it down it allows movement. | ||
|  3rd Sep 2016 7:42pm |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189      | did you also add any foam sheeting on the inside of the door card? | ||
|  3rd Sep 2016 7:43pm |
 I didn't but might do as I have done in the back and under seats,   Click image to enlarge   Click image to enlarge   Click image to enlarge All helps in my book  | ||
|  3rd Sep 2016 7:51pm |
| Posting Rules
