Home > Maintenance & Modifications > Sound insulation for the doors
SkyFallSilver
Kuwait
Hello,
Has anyone done sound insulation for the doors ? How many meters do I need or the quantity ? 2016 Defender 90 Adventure Edition
Post #560556 1st Sep 2016 6:07pm
DOOFER
i used 1 1/2 sheets of 18x32 dynamat DON'T PANIC
Post #560609 1st Sep 2016 8:51pm
Stacey007
Hello
I used silent coat 2mm deadening, only done the two front doors not the rear or passenger ones yet. (mines a 110)
1 bulb pack covers a huge area, biggest difference is the doors (sound much less like a tin can)
Then the seat boxes make a big difference
Sorry not sure how many sheets but not many for the doors, maybe 3 sheets each door?
Post #560611 1st Sep 2016 8:54pm
How did you get it behind there? I'm assuming fit it in then remove the backing tape stuff in situ?
Post #560619 1st Sep 2016 9:01pm
SkyFallSilver
Kuwait
Ordered these can't wait to install them, hate the sound of the door when it shuts and want more noise insulation. 2016 Defender 90 Adventure Edition
Post #561015 3rd Sep 2016 11:33am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i've done all below window height apart from my doors so i will be interested to hear if it makes a difference and what you do
Post #561122 3rd Sep 2016 8:33pm
Stacey007
Hello
The silent coat is easy to work with Smile
I removed the backing sheet and then you can move it into place before you actually push it down. I used a decorating roller for that part. Its tacky but until you push it down it allows movement.
Post #561127 3rd Sep 2016 8:42pm
bm52
did you also add any foam sheeting on the inside of the door card?
Post #561129 3rd Sep 2016 8:43pm
Stacey007
Hello
I didn't but might do as I have done in the back and under seats,
All helps in my book Smile
Post #561133 3rd Sep 2016 8:51pm
