Home > Technical > Steering guard fitment, 300tdi & puma
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
Hi guys, quick question.
I'm wanting to buy a steering guard, advertised on here. He said he has it fitted on a 300tdi 110. I have an 09 xs puma with air con. Does anyone know if it will fit mine? Or weather they have changed slightly over the years? Will the air con make a difference?
Cheers, Christian
Post #535389 28th May 2016 2:49pm
Mo Murphy
It will fit Christian.
HTH
50 Shades of Pennine Grey
Post #535422 28th May 2016 5:22pm
As Mo says. It'll fit. BUT.... it's a royal PITA to fit to the puma's as you can't get your arm down inside the engine bay to get a nut on the fixing bolts.
I helped a forum member fit a Mantec ali guard to his puma 110, I have the same guard on my Td5.
Mine was about 1000x easier to fit.
Post #535508 28th May 2016 10:13pm
Christian1402
Thanks for the replies guys, much appreciated
Post #536351 1st Jun 2016 12:31am
driver9
Purchased a steering guard from Paddocks for my Puma. No problem fitting, just removed a couple of bolts from the front chassis rails (accessed from underneath) and replaced with those supplied in the kit.
Post #536368 1st Jun 2016 7:36am
